Wacky Tacky - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 05-25-2009, 08:31 PM Thread Starter
Ba dum dum, ching...
Ron_G's Avatar
Wacky Tacky
OK, I've looked through the fourm search and the vulcan verses and I think I might know what the problem is but since my issue doesn't relate exactly I'd like some confirmation or comment on this...
Normally when I'm riding at 55 MPH the tach is rock solid at 3500 rpm. but today when I was riding at 55 MPH the tach was jumping around between 3200 and 4000 RPM. It doesn't do it below 3000 or above 4000. I can't hear the engine miss or surge at this speed and I don't feel an loss in power. From reading other posts on electrical I'm thinking that it might be the coil or ignitor but I'm a total novice on wrenchin on this bike so I'm looking for a little help.
BTW sorry Cindy I hit the wrong button and it posted before i finished the first post.
r
Yes, it's my mid-life crisis.
Sweet Jane...
http://images5a.snapfish.com/232323232%7Ffp63386%3Enu%3D457%3A%3E6%3C3%3E258%3E  WSNRCG%3D3345343785349nu0mrj
Ron_G is offline
post #2 of 12 (permalink) Old 05-25-2009, 08:33 PM
flitecontrol's Avatar
I'm not sure I understand the problem....?
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #3 of 12 (permalink) Old 05-25-2009, 08:51 PM
Crobins365's Avatar
Your tach jumping around, Ron?
C
Crobins365 is offline
post #4 of 12 (permalink) Old 05-25-2009, 08:54 PM
Posting in riddles.
post #5 of 12 (permalink) Old 05-25-2009, 10:09 PM
The Professor
lance328's Avatar
Make sure you frame grounds under the seat are clean and tight.
It happened to me last fall around the same rpm's. It didn't bother me enough at the time to start looking for the source since the engine was running fine. About three weeks later I was doing a nut and bolt check and found that the frame ground was a little loose. My tach has not acted up since then, yours may have the same problem or your tach could be crapping out.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #6 of 12 (permalink) Old 05-26-2009, 12:20 AM
It sounds like the problem is only with the tachometer, since you aren't suffering from a loss of power or surging. Could it be the tachometer cable that is malfunctioning?
Harvey_birdman is offline
post #7 of 12 (permalink) Old 05-26-2009, 12:24 AM
I think the tach is electical, the speedo has a cable.
post #8 of 12 (permalink) Old 05-26-2009, 12:27 AM
Well, wire then.
post #9 of 12 (permalink) Old 05-26-2009, 02:51 AM
if the wire were loose, the tac would drop down to zero, now I am thinking a faulty tac since there is no noticeable engine problems. Try disconnecting the tack, and go for a ride and see if you can feel or hear the engine acting up. The reason for unplugging the tac is to make make you concentrate on the bike and not the numbers.
if your bike surges, and stumbles I would look into fuel delivery problems and your pickup coils
you might have a lose connection on the pickup coil.
post #10 of 12 (permalink) Old 05-26-2009, 07:46 AM Thread Starter
Ron_G's Avatar
Thanks guys.
I'll check for a loose connction or frayed wire first amd return with the results.
R
Sweet Jane...
Ron_G is offline
