stebel air horn - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 05-15-2009, 07:57 PM Thread Starter
cm4cm5's Avatar
stebel air horn
ok..im installing air horn, got it all hooked up, but connecting the horn butten wire, the horn sounds, tried all wires, 2 wires are ground, no sound, 2 wires hot, touch wires, horn sounds. what am i doing wrong.
reconnected wires to stock horn, befor trying another, same outcome.
return allwires to stock, butten works fine.
help please.
p.s....stebels are loud as he**...lol
Jeff Brooks
Owensboro KY
'94 Vulcan 750
cm4cm5 is offline
post #2 of 9 (permalink) Old 05-15-2009, 08:42 PM
I have a diagram that I copied here that I`m working from, but have not as yet actually hooked a relay up. A standard 4 terminal relay should have a number beside each terminal.
#30 should be a red lead (at least 16 gauge wire I think) with a 20 amp fuse and holder installed, going to the battery positive post.
# 87- continue 16 gauge red wire to compressor positve terminal.
From compressor negitive terminal run a 16 gauge black wire to a good frame ground.
# 85 and 86 are connected to the trigger wires coming from the horn switch.
When the the horn switch is pressed, and the #85-86 circuit is closed, you should hear a click as that switch closes the circuit between the Battery and compressor. I hope this is right and helps you.
post #3 of 9 (permalink) Old 05-16-2009, 12:45 PM Thread Starter
cm4cm5's Avatar
ok, ive figured it out and got it working right. i guess thats what the wiring diagram is for...lol
but seriosly, if enyone is getting this horn, do not get the prewired plug and play kit, its useless. all i needed was the relay, fuse, red wire. and about a foot of the black ground wire. the rest is going into my scrap wire bin for other uses.
ill get pics in awhile and get a sound bite after i get my bike back together.
Jeff Brooks
Owensboro KY
'94 Vulcan 750
cm4cm5 is offline
post #4 of 9 (permalink) Old 05-16-2009, 07:39 PM
750Doug's Avatar
Pics please. I'd like to see where/how you mounted it.
750Doug is offline
post #5 of 9 (permalink) Old 05-16-2009, 07:53 PM Thread Starter
cm4cm5's Avatar
look in "stock horn -v- stebel"..i posted links to sound bites on youtube.
Jeff Brooks
Owensboro KY
'94 Vulcan 750
cm4cm5 is offline
post #6 of 9 (permalink) Old 10-20-2009, 05:04 PM
KIMMERLING's Avatar
I totally agree man! Do not buy the plug in play kit...waste of money and time...i still wound up making trips to get wire and connectors....I appreciate all of your input on what wire goes where...etc....it totally helped!
Ventura guards
MadStadt mount
Givi windshield/Heated grips
Backoff
Riderbeads
Givi 52 topcase
OEM centerstand
Headlight modulator
Battery tender
KIMMERLING is offline
post #7 of 9 (permalink) Old 10-20-2009, 05:56 PM
Chavisimo's Avatar
cm4cm5, which stebel horn did you get? Can you give a link? Thanks!
BTW, nice sound files
VROC Number: 31246
2003 Kawasaki VN750 SOLD
2006 Honda VTX1800C
Chavisimo is offline
post #8 of 9 (permalink) Old 10-20-2009, 07:01 PM
CWO3 Navy (Retired)
cliffhusn's Avatar
Stebel Air Horn
Here is how I mounted mine. Made a very simple L bracket, drilled a hole in each side, mounted it to the bike first then the horn to the bracket. Holds tight and looks great. It's mounted on the screw that holds the left air cleaner housing.
cliffhusn is offline
post #9 of 9 (permalink) Old 10-21-2009, 10:07 AM
GIMPYRDR's Avatar
Mine isn't the Stebel, it is the Bad Boy.
https://www.vn750.com/photopost/data/500/IMG_0730.JPG
In the pic you can see I mounted mine on the neck cover, just in front of the tank above the air filter box (ear).
2005 Vulcan 750
Black and Silver
Saddlebags
OEM Hghwy Bars
O-ring Footpegs
OEM Luggage Rack
V&H Exhaust System
TOC ACCT Rebuild
Die Hard Gold AGM MFB
Spline Lube every tire change
VN750 #4393
VROC #31065
TexasVROC
GIMPYRDR is offline
