Wiring Woes... when i jiggle my tank the Neutral light goes off - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 05-10-2009, 04:32 PM Thread Starter
When i jiggle my tank the Neutral light goes off and the bike wont start. If jiggle it again the light comes on and the bike runs. Is it something in the main wiring harness?
dubious is offline
post #2 of 7 (permalink) Old 05-10-2009, 04:41 PM
flitecontrol's Avatar
More than likely.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #3 of 7 (permalink) Old 05-10-2009, 04:44 PM
Maybe your wires are pulling out of the ignition switch??
post #4 of 7 (permalink) Old 05-10-2009, 06:20 PM
750Doug's Avatar
It's not uncommon for a problem to develop in the harness at the bend around the neck and into the ignition switch....
Just replace harness with part from EBay.
(yes, the ebay thing is just a joke)
750Doug is offline
post #5 of 7 (permalink) Old 05-11-2009, 01:23 PM
The wiring harness is also prone to fraying appart under the Fuel tank, where the seat and tank join. you ave a couple of options to fix this problem. The first and best and easiest is to replace the harness. Another is to bypass the neutral safety switch, and lastly, is to run a new wire for the NSS
post #6 of 7 (permalink) Old 05-11-2009, 01:37 PM
the doctor
billryx's Avatar
check the two bullet connectors at the plug-socket brack under the tank. The two wires are colored brown/white and white if they do not make good connection then the bike won't start. These two can become burnt, just wiggle loose or break at the connector. Replace the connectors (do not have to be bullet type but must be fully insulated when connected) if you find a problem.
bringing together
a dead
'86 VN750
"it's alive":"krechure"
billryx is offline
post #7 of 7 (permalink) Old 05-19-2009, 02:02 AM
nice -thanks guys, ive also started to have this little problem recently. as always, vn750.com rocks!
jetboy is offline
