Intermittent Headlight Flickering - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 05-06-2009, 05:36 PM Thread Starter
Returning from a recent night-time ride, the headlight and instrument lights began fllickering intermittently. This lasted about 20 minutes until I pulled off the highway and stopped at a traffic signal light, whereupon the engine staggered and died. It was like someone had just turned off the ignition. The bike started right up when I pressed the starter button and, by keeping the rpm above 1500 or so, I got home OK. Checking things yesterday in my garage, the battery voltage varied from about 12.5 at idle to a steady 14.5 at 3000 rpm; clamp-on ammeter around the negative battery lead showed
-0.8 amps at idle, +0.8 to +2 amps at 3000, but no flickering of lights at all. Don't know if this variability in ammeter reading is a characteristic of the ammeter, or might indicate a loose connection somewhere in the charging circuit, ...or?
Richard.williams is offline
post #2 of 6 (permalink) Old 05-06-2009, 06:59 PM
The Professor
lance328's Avatar
Check your frame ground beside the battery and check the ignition switch.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #3 of 6 (permalink) Old 05-20-2009, 03:21 PM Thread Starter
Thanks. I will check those things.
post #4 of 6 (permalink) Old 05-20-2009, 05:36 PM
Undercover Sportbiker
AJCruzin's Avatar
Normally, a phantom like that is a loose connection. Batt wires, ground wire at the batt, also people have had issues with "older" ignitions cutting out intermittently.
AJCruzin is offline
post #5 of 6 (permalink) Old 06-30-2009, 05:38 PM Thread Starter
Must have been a bad connection at the battery. Re-tightened both positive and negative. Took an all day ride - no problems. Thanks to all.
post #6 of 6 (permalink) Old 07-01-2009, 04:40 PM
tankist's Avatar
Send a message via Skype™ to tankist
havent posted i a while, good to see this is still going and going well
and as far as the topic i would check the other side of that ground cable as well as its overall soundness just to make sure. i had thta cable just snap on my in the middle of street. not pleasant
Ride Safe
Anton.
tankist is offline
