Quick ignition coil question - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 05-05-2009, 04:11 PM Thread Starter
I just now remembered the question I was trying to think of all day....
On the ignition coils, which wire goes to which connector? I found a reference to the front coil having the red wire towards the front of the bike and the black wire towards the rear, but no mention about the other coil. I have searched through both manuals and googled and I can't find the answer. Does the Red go on top or bottom on the rear coil?
I'm at a point where I am ready to start the motor for the first time since I started tearing everything down and I don't want to blow anything right off the bat. Thanks in advance for the info.
Chiron
Chiron is offline
post #2 of 3 (permalink) Old 05-05-2009, 04:40 PM
The Professor
lance328's Avatar
It really doesn't matter but rear coil red on top and front coil red toward front.
Before you start the engine remove the plugs and turn the engine over untill the oil light goes out to prime the system.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #3 of 3 (permalink) Old 05-05-2009, 04:47 PM Thread Starter
Thanks Lance. I didn't *think* it mattered, but after all of the hard work I have put into this, I didn't want to screw something up royally the first time I try to start it up. Besides, it never hurts to double check things.
Thanks again.
Chiron is offline
