No Headlight - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 38 (permalink) Old 05-03-2009, 07:46 PM Thread Starter
Jace Bror's Avatar
No Headlight
now I have a new gremlin. No headlight. bulb checks out and fuse is okay. and the headlight indicator doesn't work either, and when I flip the lites from low to high the highbeam indicator doesn't lite up either. only thing I did electronically is stand up and whallop my head on the underside of the left controls.
Jace Bror is offline
post #2 of 38 (permalink) Old 05-03-2009, 07:51 PM
Simple Solutions
seebeeare's Avatar
its may 3rd u forgot turn key 3 times run around bike twice honk horn start bike take 2 deep breaths a walla light should work...
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
How To Test the Stator
seebeeare is offline
post #3 of 38 (permalink) Old 05-03-2009, 07:55 PM Thread Starter
Jace Bror's Avatar
that was the first thing I tried actually.
post #4 of 38 (permalink) Old 05-03-2009, 08:01 PM
Simple Solutions
seebeeare's Avatar
light only turns on when the bike is started so im assumng there is a relay somewhere connected to the headlight that starts when there is a pull from the starter i believe somone called it a headlight controller my best guess is there ...
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
post #5 of 38 (permalink) Old 05-03-2009, 08:05 PM Thread Starter
Jace Bror's Avatar
yup I know the bike has to be running. I have no power in the fuse junction box either. all the other ones do, but just not the headlight fuse
post #6 of 38 (permalink) Old 05-03-2009, 08:13 PM Thread Starter
Jace Bror's Avatar
scratch that I do have power at the fuse. but still no power at light
post #7 of 38 (permalink) Old 05-03-2009, 08:14 PM
The Professor
lance328's Avatar
The relay is inside the JB, some people move the wire to the accy. terminal and bypass the relay or replace the JB.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #8 of 38 (permalink) Old 05-03-2009, 08:32 PM
I would look for the problem at the whalloped control.
post #9 of 38 (permalink) Old 05-03-2009, 08:34 PM Thread Starter
Jace Bror's Avatar
but if you use the accy you don't have high beams right? but it would last me til I get a new JB
post #10 of 38 (permalink) Old 05-03-2009, 08:38 PM
Simple Solutions
seebeeare's Avatar
with power at the fuse wouldnt it be the same on the acc?
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
