thought i had a kill button - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 18 (permalink) Old 05-01-2009, 12:12 AM Thread Starter
electrum's Avatar
Unhappy thought i had a kill button
ok, this was stupid... my other bikes all had a kill button on the right handlbar where the Vulcan has the starter button.
so the other day i was operating by habit and hit the starter button to turn off the engine... the lights kind of dimmed but of course it didn't turn off... so i hit it a few more times. finally i flipped the run switch to off.
it wasn't until just now that i realized i was hitting the starter button
so 2 questions... did i hurt anything? i didn't hear any grinding like on a car when the starter tries to engage a running flywheel.
and why isn't there some kind of lockout to prevent me from being so stupid!
because i bet i do this a few more times before i get in the habit of hitting the kill 'switch'.
96 Vulcan 750
electrum is offline
post #2 of 18 (permalink) Old 05-03-2009, 12:12 AM
As Ron White said "You can't fix stupid"
But most importantly, you should not be using the kill switch to turn the engine off, you should be using the ignition key. Doing this will solve your problem too.
The Kill switch was designed for emergency use, not everyday use.
The starter does not "engage" like it does on a car, so I would guess you didn't hurt anything, other than perhaps your reputation here.
post #3 of 18 (permalink) Old 05-03-2009, 07:22 AM
ptcbob
ptcbob's Avatar
electrum, If occasional stupid acts were fatal, this forum would not exist. I have done much worse. Don't feel bad. We still call you friend and brother.
Bob
ptcbob is offline
post #4 of 18 (permalink) Old 05-03-2009, 03:44 PM
flitecontrol's Avatar
Guess I'm real slow on the learning curve. Done it several times on both my bikes, and suspect it might happen again.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #5 of 18 (permalink) Old 05-03-2009, 06:55 PM
Love My Baby
rubyrick's Avatar
...you should not be using the kill switch to turn the engine off, you should be using the ignition key...
Quite right! While the kill switch does work well to turn the engine off, the ignition key will still be in the ON position, draining the battery. Turning the engine off with the ignition key will turn off all the electrical devices that run off the ignition switch, saving your battery's power.
Rubyrick
MY BABY...
'05 VN750
16,000 miles +
Kawi tank bib
Kawi rear rack
Small windshield
DEKA M/F battery
LED license plate frame
X
rubyrick is offline
post #6 of 18 (permalink) Old 05-04-2009, 12:03 AM Thread Starter
electrum's Avatar
ok, thanks.. good advice...
this is the first bike i've had with a starter... its going to take some getting used to...
a number of times already i've raised up my right foot ready to kick it over !! now that looks real intelligent!
96 Vulcan 750
electrum is offline
post #7 of 18 (permalink) Old 05-04-2009, 12:14 AM
The Professor
lance328's Avatar
Just curious, have you been hitting the horn when trying to switch to high beam? LOL
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #8 of 18 (permalink) Old 05-04-2009, 01:02 AM
The starter button on my Honda ATV is where the horn is on the VN and I am always in a crowd when I hit the horn button just after getting all geared up and ready to roll,although it is fun to see the surprised look on some peoples faces as the walk by and I blow the horn at them,I have learned to wave also so they think they know me and start up and leave before they realize I just did something stupid.
post #9 of 18 (permalink) Old 05-04-2009, 09:15 AM
Yes, it's part of my embarassment ritual. For a great finale, I get off the bike without putting the kickstand down! Really an attention getter!
"Black Beauty"
Old Blue
post #10 of 18 (permalink) Old 05-04-2009, 10:06 AM
750Doug's Avatar
I know a guy who stopped for a red traffic light and didn't put his feet down....
750Doug is offline
