yellow wire alternator confusion???? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 04-29-2009, 02:49 PM Thread Starter
wpilgrim's Avatar
Hey all first post so bear with me. Me and a buddy of mine both have vulcan 750s mine a 94 his a 90 recently we discovered that he bought the bike with a bad stator so long story short we have pulled the engine went through an all around inspection (which we found other things to replace such as his final drive and drive shaft coupling) and replaced his stator.
We did a great job of labeling every wire, hose, and screw we could get our hands on so we would know where to replace it but unfortunately we slipped with the 3 yellow wires that come out of the alternator case and connect back on to the bike. We know where they connect (ie their female counterparts) we are just not sure about in which yellow wire connects to which female lead. We have an idea furthered by a nice colored wiring diagram that I found on here that it doesn't matter as all of them go back to the voltage r/r.
Is this true or is their a specific set up that we should be aware of?
hope all of that made sense and thanks ahead of time for the help
wpilgrim is offline
post #2 of 7 (permalink) Old 04-29-2009, 02:52 PM
I can't help you with this, but I am sure someone here can.
Welcome to the group.
post #3 of 7 (permalink) Old 04-29-2009, 03:02 PM
93VN750's Avatar
It doesn't matter, each one is it's own phase, just connect one to one, don't worry about position.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #4 of 7 (permalink) Old 04-29-2009, 03:54 PM
fergy's Avatar
Only thing is make sure each of the yellow wires from the stator go to any of the three positions on the r/r where a yellow wire is supposed to be. i.e. don't hookup a yellow where the brown should go etc.
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #5 of 7 (permalink) Old 04-29-2009, 05:44 PM
make sure that all the connections are solid and clean also ,I cut the bullet connectors off and soldered mine,these bikes are very sensitive about bad connections as they lead to all kinds of funky and weird problems,especially frame grounds and battery to frame connections,Denny
post #6 of 7 (permalink) Old 04-30-2009, 12:19 PM Thread Starter
wpilgrim's Avatar
Hey I appreciate all you guys help with this. I think that answers my question just fine.
Although his bike has had some problems I have to say tearing this thing apart and learning the inner workings of the bike has been a blast. (I prob feel this way because its not my bike but my buddies, mines runnin great knock on wood!) We're tryin to get this thing put back together by next weekend as we have a couple buddies coming down for a ride, fingers crossed.
wpilgrim is offline
post #7 of 7 (permalink) Old 04-30-2009, 12:48 PM
Simple Solutions
seebeeare's Avatar
next tear down will take half the time after 3 pulls im down to about 2 hrs and engine is out
those wires just plug in and like stated earlier make sure they are clean and secure
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
How To Test the Stator
seebeeare is offline
