New model "Delta Force" stator, 30-33 amps, mentioned in vulcan verses. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 04-25-2009, 04:31 PM Thread Starter
Question New model "Delta Force" stator, 30-33 amps, mentioned in vulcan verses.
I was just perusing the verses and noticed some references to higher power stators than Ma Kawi`s OEM output of approximately 21 amps.
In about 2005, Electrosport had a model# G-05 which produced 26 amps, for ~ a 25% increase.
There was a higher power, "Delta Force" 30-33 amp stator, in development at that time. It would have required a new higher power RR matched to it. Does anyone know if this stator/RR combo was ever completed and released to the public? I don`t believe that the current stator that electrosport sells is much different in capacity than Kawi`s OEM.
post #2 of 4 (permalink) Old 04-25-2009, 08:42 PM
According to Maw Kaw's manual, the stock output is 24A @ 8,000rpm, 14V; that's less than a 1% increase in output, if I did my math correctly, and my math may be suspect, too. <G>
That said, 21A @ cruise may be about right, but I don't have an ammeter hooked up to my bike to be able to tell--and not sure I could get one wired for an accurate reading if I did!
However, to answer your primary question, I don't recall anything ever coming of the "Delta Force" stator/RR combo; never read or heard anything, anyway. I do recall someone selling a stator with a little bit more output, but not that much I don't think; Willie's Cycle, maybe?
Jim
J.D.
Kerrville, TX
'95 Vulcan 750 "Therapy II",
aka "Raggedy Ann"
'95 VN750 project
'03 VN800B "The Little Black"
'04 VN800E Drifter project
'93 VN1500A custom project
VROC #16185
GCVROC #33
J.D. is offline
post #3 of 4 (permalink) Old 04-27-2009, 11:40 PM Thread Starter
Jim
Hey JD, you`re right about the 24A @ 8,000rpm, and I saw it in the verses too. I must have had a brain fart when I read it, because I was thinking that was over the redline of 7,500 rpm. Of course I remember now the redline is 8,500 rpm. Now, 21 Amps is all I`m ever likely to get from my stock stator, because 6 grand is about as fast as I`m ever likely to cruise on my vn.
Your math is a little off though. An increase from 24 to 26 amps gives a ratio of 2/24 which =1/12 = 8.33%.
I doubt that we will ever see a stator able to generate the power that the Delta Force was hoped to make. But a stator that would give us 26 amps at a cruising speed of 70 mph, and engine speed ~5,000 rpm, would be just about a 24% increase over the Kawi OEM. This would give us a lot more flexibility in adding electrical goodies to the vn.
I`ll check willies cycle and see what I can find.
edit: Only find willies cycle salvage.
post #4 of 4 (permalink) Old 04-29-2009, 09:32 AM
<G> 6 grand will still get you ~80mph! As for the math...suffice to say, it was a long day, and I'd just gotten my engine back in the bike for the second time in two weeks--after changing the stator <g>--and the damn thing wouldn't run right. Carbs sat too long, I do believe... And as for having to pull it twice, I somehow got the cover gasket hung above the shifter shaft; major oil leak. That's what I get for tilting it the first time, instead of just pulling it all the way out like I should've in the first place.
I think willies cycle salvage is the one, but I must've been mistaken about them being the one offering higher output stators. Rick's doesn't show one either, so beats me now who it was. Oldtimer's Disease...
Jim
J.D.
Kerrville, TX
aka "Raggedy Ann"
'95 VN750 project
VROC #16185
GCVROC #33
J.D. is offline
