Regulator Problem, Not Sure. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 04-25-2009, 02:58 PM Thread Starter
IBEW 915 Electrician
hctublerub's Avatar
I've been tracking this for a while wondering if I have a stator or regulator problem. Today I took one of those cheap digital meters ($20) you get from Home Depot, put spade lugs on the leads, hooked to battery, and ty-rapped it between the tach and speedo.
Took the bike out and the numbers were good. 13.8-14.0v. After about five minutes of running the numbers suddenly dropped to about 12.5 and began to go lower. The battery drained close to 12v by the time I pulled into the drive.
I had hooked up an O-scope earlier and saw what I thought to be a sizable AC ripple across the battery.
The bike also stalls at idle even with the good voltage so I think there are some other issues. Starts up quick, though.
After reading the Vulcan verses I think this is the regulator.
Butch
'01 Vulcan 750
Irridium Plugs
hctublerub is offline
post #2 of 6 (permalink) Old 04-25-2009, 05:56 PM
The Professor
lance328's Avatar
Butch
Do some more rides with the meter, I think your R/R is fine. Sometimes at low rpm it can dip below 12v.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #3 of 6 (permalink) Old 04-25-2009, 10:05 PM
Also, pay attention to when the voltage drops to see (or listen) if the fan is running, maybe while the brake is being applied too?
The fan & brake together will put a pretty good drop on the voltage.
post #4 of 6 (permalink) Old 04-26-2009, 01:15 AM Thread Starter
hctublerub's Avatar
The dip occurred as I pulled away from a stoplight and never recovered. There were stops before that happened and the voltage remained OK. On one of my earlier rides I pulled into the drive and the engine stalled. The battery was too weak to restart the engine. As it stands now I can't really ride the bike too far from home.
The bike is firing a bit uneven at the lower rpms even though it seems to have power.
I'll take the bike out a few more times and pay more attention to what I am doing when this occurs.
Put into the Kawasaki dealer a few months back and they come up with zero after a day of "diagnostics". It cost me $133.
'01 Vulcan 750
Irridium Plugs
post #5 of 6 (permalink) Old 04-26-2009, 03:54 AM
The Professor
lance328's Avatar
Check all battery, solenoid, R/R, stator and ground connections.
How old is your battery and what type?
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
post #6 of 6 (permalink) Old 04-26-2009, 11:24 PM Thread Starter
hctublerub's Avatar
Battery is a new Westco MF AGM. I bought the charger offered with it and it seems a good match. The charger can be left on the battery without overcharging.
'01 Vulcan 750
Irridium Plugs
