Battery question - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 04-23-2009, 06:53 PM Thread Starter
Benjammin'
BSkaggs513's Avatar
Battery question
There have been a lot of posts in here about batteries recently and some really great info as well. Here is my question to all the battery experts out there;
Since our bikes run on 12v, other than initial starting, how would more cold cranking amps be beneficial in a battery? If the bike recharges the battery sufficiently, the battery takes the charge OK and it then measures 12v when just sitting, why spend more money on a higher CCA battery? Does any 'more' power contribute to the bike's runnability after starting?
Also, other than potential leakage of a wet cell and the other 'maintenance' issues, if it works with the 12v system mentioned above (sufficient CCA to start, recharges and holds 12V), then why would a wet cell not work?
I have a AGM battery in my bike that will need replacing soon. I will replace it with a AGM because I don't want acid leaking on parts of my bike. But I want to make sure I get the right battery- one that will last, but not overspend for CCA because I am typically a fair (and warm) weather rider. I may not need the extra boost from higher CCA because bike is typically warmer whan I start it.
Thanks everyone!
Ben-
Ben-
SW Ohio
'02 VN750
Pipes drilled
Spline lubed
AGM batteried
Iridium equipped
LED tail lighted
8000-ish miled
Soon to be MCCTed
Lovin Life.
BSkaggs513 is offline
post #2 of 9 (permalink) Old 04-23-2009, 07:06 PM
The Professor
lance328's Avatar
The best battery for the money is the Deka/Big crank, they are made in USA and have 1 year no BS free replacement warranty. The CCA was upped to 210 in 09-08'.
DEKA
http://cgi.ebay.com/ebaymotors/Deka-...ehicleQ5fParts
BIG CRANK
http://www.batterymart.com/p-Big-Cra..._campaign=Base
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #3 of 9 (permalink) Old 04-23-2009, 08:26 PM
Gemguy's Avatar
It's not an easy explanation Skaggs. There are batteries made that are deep cycle that can deliver a heavier surge for starting. It is all at 12 volts but it refers to the current (ampere) delivery for a short burst. They will recharge and continue to deliver 12 volts until they get seriously discharged. Beyond the amp/hours that the batteries will deliver, some of them deliver better up front and some deliver evenly during the whole discharge cycle. Hope that helps
~VROC~ # 389
Gemguy is offline
post #4 of 9 (permalink) Old 04-23-2009, 09:44 PM
Love My Baby
rubyrick's Avatar
A good AGM battery also holds it's charge longer than a wet cell, so you won't have to connect a battery charger to it as often. This is especially important to you when you store your bike for the winter months. You're battery won't be dead or weakened when you start her up in spring/summer, compared to a wet cell. As for CCA, the larger the CCA the easier it is for the battery to start you up even when there is a higher load on the battery. Sometimes the resistance along the circuit is increased for a variety of reasons: temperature, corrosion, additional lighting or other electrical components added on, etc.
Rubyrick
MY BABY...
'05 VN750
16,000 miles +
Kawi tank bib
Kawi rear rack
Small windshield
DEKA M/F battery
LED license plate frame
X
rubyrick is offline
post #5 of 9 (permalink) Old 04-24-2009, 12:45 AM
The most important is how much cranking amps the battery gives. If not enough, the motor turns slowly and the voltage drops so that you may not have a spark at all. I still have a wet cell battery, but when the time comes will replace with an AGM battery. Main reason is to prevent rusting around the battery (and yes, it is better in other features too).
pappa is offline
post #6 of 9 (permalink) Old 04-24-2009, 10:49 AM
Yes, CCA's refers to what a battery will deliver in cold conditions, but, the way I see it, if it has higher CCA's when it's cold, it also has more in warmer temps, which means easier starting because of not getting low spark at the plugs (which often happens with standard wet cell batteries)
post #7 of 9 (permalink) Old 04-24-2009, 11:08 AM
cglennon's Avatar
Thanks everyone!
Ben-
There are technical reasons why a AGM is better than wet, most importantly its slow rate of self discharge; better starting after sitting for long periods of time, less load on the charging system, etc.
Stick with AGM for now.
Chris Glennon - Portland, OR
cglennon is offline
post #8 of 9 (permalink) Old 04-24-2009, 08:32 PM Thread Starter
Benjammin'
BSkaggs513's Avatar
I will get an AGM. My 3 year old AGM crapped out Autozone's testing gave her the thumbs down. The bummer is that the wet cell I had lasted longer!
I have had good starts with both AGM and wet cells, but I don't like getting acid all over the battery box is mainly why I'm going with AGM again. From what I gather, CCA's are primarily there to add extra power to turn over the engine. Less power used is less voltage required to get the battery charged again. From what I read, this is where the strain occurs on our charging systems. Did I sum everything up properly?
Now, what brand of battery is the best quality and who has the best price on it?
Ben-
SW Ohio
'02 VN750
Pipes drilled
Spline lubed
AGM batteried
Iridium equipped
LED tail lighted
8000-ish miled
Soon to be MCCTed
Lovin Life.
post #9 of 9 (permalink) Old 04-24-2009, 09:07 PM
The Professor
lance328's Avatar
DEKA/BIG CRANK
CCA was upped to 210.
http://cgi.ebay.com/ebaymotors/Deka-...QQcmdZViewItem
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
