Does your bike have a VAG? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 13 (permalink) Old 04-21-2009, 01:54 PM Thread Starter
I was talking to someone and they said some bikes use a variable ammeter guage, rather than a digital internal commutator? Im a bit confused and thought Id ask here?
Custom Cow is offline
post #2 of 13 (permalink) Old 04-21-2009, 02:49 PM
I have never heard of either one before. It sounds like the guy who sent the new kid to find a rubber monkey wrench to me.
If the amps do not vary, you would not need a gauge. An ammeter gauge would indicated how the amps vary, but would not properly be called a variable ammeter gauge.
The digital internal commutator, are nonsense words to me.
A commutator is on the end of a shaft in a starter, alternator, or generator with many copper sections where the electrical brushes make contact.
It is a good thing you have been around awile CC, or I would probably have flagged this post as SPAM. LOL. Maybe it will make sense to someone else, but not me.
post #3 of 13 (permalink) Old 04-21-2009, 04:38 PM
Yes, it goes right under the flux capacitor and is wired directly to the Heisenburg compensator.
No one uses the digital internal commutator (DIC) anymore for obvious reasons, why have a DIC when you can have a VAG right?
Someone is yanking your chain real hard there Cow...or are you yanking ours?
post #4 of 13 (permalink) Old 04-21-2009, 04:49 PM
Simple Solutions
seebeeare's Avatar
dont forget to pick up your metric crescent wrench
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
How To Test the Stator
seebeeare is offline
post #5 of 13 (permalink) Old 04-21-2009, 04:55 PM
93VN750's Avatar
Was gonna do that after I change the blinker fluid.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #6 of 13 (permalink) Old 04-21-2009, 05:05 PM
Simple Solutions
seebeeare's Avatar
muflfer bearings too
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
post #7 of 13 (permalink) Old 04-21-2009, 08:48 PM
now i saw VAG and thought this was about something completely different in general.... i know we call them hers but saying my bike has a vag is going a little over board...
bigrepp61 is offline
post #8 of 13 (permalink) Old 04-21-2009, 08:58 PM
D2u
D2u
D2u's Avatar
Lmao
1992 VN750 22,350 miles 18,700 when I bought it last year 04/17/2008
Streetshield EX
degoat
drilled mufflers
Capped (soon to be coaster)
Custom Grips
Wide blade levers
Throw over leather saddlebags
Deka MF AGM ETX15L
NGK Iridums
DIY Brackets,and highway pegs
To do list.
custom seat
teardrop mirrors
DIY Floor boards
D2u is offline
post #9 of 13 (permalink) Old 04-21-2009, 09:37 PM
Expert Advice Giver
mgough983's Avatar
When you're facing the tail of the bike, is the VAG on the left or the right? I don't want to accidentally perform a Dirty Sanchez in the garage. Not by accident at least.
1994 VN750
32K+
Vance & Hines Cruzers
Avon Venom Front & Rear Tire
Mustang Seat
Fire and Steel Luggage Rack
Fire and Steel Engine Guard
Fire and Steel Sissy Bar
KawaVulcan Saddlebags
eBay Genuine Imitation Chrome Mirrors
Kury Chrome Levers
Battery Tendered
Taillight LED'd
Splines Lubed
Wheelies Popped
2009 Triumph Rocket III
1974 Suzuki TS250
mgough983 is offline
post #10 of 13 (permalink) Old 04-22-2009, 01:01 AM
gusdaman89's Avatar
Depending on your year- the VAG may use insulated-gate bipolar transistors which have either reverse transfer capacitors or the pulse-width-modified tri-polar vacuum tubes. These both contain Zener diodes that allow voltage to pass when the magnitude of the amperage varies more than + or - three standard deviations from the normal value. On the other hand the digital internal communtator amp meter measures amperage without the use of solid state devices.
Hope this helps.
Project Black and Gray
2004 VN750
Arlen Ness Mirrors
Custom covered seat
Custom taillights
Fenders undercoated
gusdaman89 is offline
