Cracked wire - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 04-18-2009, 02:24 AM Thread Starter
Cracked wire
So i got curious and started examining my bike.
Under the fuse box there is a plug with many yellow wires and one brown wire.
the brown wire has damage to it. is this brown wire why my rear left turn signal doesnt work?
6204 is offline
post #2 of 3 (permalink) Old 04-18-2009, 02:39 AM
The Professor
lance328's Avatar
That is your R/R plug, it should have 3 yellow wires on top and 1 black, 1 brown, 1 white wire on the bottom. The brown wire goes to your junction box and this will NOT effect your turn signal, but do repair the wire. Check your bulb, socket and wires to the signal.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #3 of 3 (permalink) Old 04-18-2009, 03:04 AM
while ive been messing about with my own bike my rear left turn signal also stopped working, i took the light apart, looks like it wasnt earthing due to corrosion. Had to give a really good clean. There is a washer at the base of the spring which the ground wire connected to. This has to touch the side of the unit for the light to work.
scotiaredd is offline
