Pickup coil mod Or Ignition coil mod - Page 2 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #11 of 13 (permalink) Old 05-21-2020, 11:26 AM
Originally Posted by AMH View Post
Wow....learning so much on this forum!! Thanks. I will start using the choke as the weather is starting to warm up and see if that gets me around the backfire and hot start issue, specially after refueling because that's the shortest time for restarting the bike. If reducing the "Spark plug " gap will reduce sparking voltage , I will try that too! Maybe I should try the "Ignition" coil mod and get power directly from battery and see if it makes a difference.
No don't narrow the spark plug gap. The gap for the pickup coils is what gets narrowed, the coils at the rotor/flywheel.
Mine always needs choked after a fuel stop. 😉
post #12 of 13 (permalink) Old 05-21-2020, 03:30 PM Thread Starter
AMH
Ok, great...I will work on the pick up coil gap as soon as I get some free time from work!
Thanks again for all the help guys!
AMH is offline
post #13 of 13 (permalink) Old 05-22-2020, 06:56 AM
1RadCJ5's Avatar
I took Spocksters advice, and choke it after a short stop when hot. Worked every time so far. If it sits 10 mins or so, no need, but a gas stop, I pull the choke, turn a few revolutions, and it starts right up. Hopefully when its smoking hot out, it works the same way. I think it will, and unless I have to mod something, I'm not going to waste time. The day will come, but for now, ride on!
1986 VN750 26,000 miles
Deka AGM Battery 4-2020
All else stock, more to come thanks to VN750.com members!
1RadCJ5 is offline
