Slow Turnover - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 2Likes
post #1 of 16 (permalink) Old 05-01-2020, 04:59 AM Thread Starter
Slow Turnover
Hi
I have an issue with my 1985VN 700 the engine is slow turning over I have replaced the battery and charged it, checked the starter motor and also tried a replacement, engine turns over but it sounds as if the battery is flat,
Can I have any ideas you may have
Many Thanks
Glyn
Glyn Jones is offline
post #2 of 16 (permalink) Old 05-01-2020, 05:26 AM
Could be a bad ground connection? Check the negative battery terminal's connection to the frame.
Could also be a bad starter solenoid or connection around there. Try jumping power directly to the starter to see if it cranks more powerfully when bypassing the rest of the bike's electrical system. If that works ok, then do the same test with the solenoid.
It does happen that replacement parts are defective, too. Is the new battery for sure good? AGM type?
Glyn Jones likes this.
Vulcan slang for newcomers
Service Manual Download
Thorn is online now
post #3 of 16 (permalink) Old 05-01-2020, 05:36 AM Thread Starter
Hi Thorn
Tried putting charger directly to starter motor and earthed on frame noting till I pressed starter then the same just turns slowly
post #4 of 16 (permalink) Old 05-01-2020, 06:21 AM
A charger won't have enough amps to properly drive the starter. You'd need to jump from the battery.
Thorn is online now
post #5 of 16 (permalink) Old 05-01-2020, 09:06 AM
+1 to what he said.
Sounds like not enough amps in the battery, or a problem with the starter assuming enough amps are getting to it.
The battery should load test at least 200-250 amps.
post #6 of 16 (permalink) Old 05-01-2020, 12:07 PM
ubertalldude's Avatar
My favorite way to rule out electrical issues is to "jump" the bike with a car battery WITHOUT THE CAR RUNNING. They typically have way higher cranking amps and capacity, just be careful not to kill your car's battery
If your bike cranks right away, you can pretty safely rule out an electrical/wiring issue. If it is still slow, you've got some digging to do.
As a curiosity, what kind of battery did you get? These bikes don't like wet cell "standard" batteries, they start a lot better with an AGM battery
Spockster likes this.
ubertalldude is offline
post #7 of 16 (permalink) Old 05-01-2020, 12:48 PM
Great tip. The starter won't take more amps than it needs, you can hook a 12v bulldozer battery to it and it won't hurt a thing.
AGM - best battery available so far. Not sure about lithium-ion, haven't used one. Wet cells are dead. AGM is not the same as a gel battery, it's better.
post #8 of 16 (permalink) Old 05-01-2020, 04:09 PM
a lithium ion battery would be even better than AGM, according to the specs, performance, ect.. problem is lithium ion batteries require very specific charging and discharging protocols and protections, other wise you get either very poor life span, or even yet, turn into a fire bomb.
the charging system in the vn750 is in NO way capable of handling a Lithium battery. so we have AGM which is nearly as resilient as the standard old flooded lead acid
post #9 of 16 (permalink) Old 05-02-2020, 10:28 AM Thread Starter
Hi, tried jump starting from car battery still only turning over slowly sounds like flat battery ?? But car battery is fully charged
Any other thoughts
Thanks
post #10 of 16 (permalink) Old 05-02-2020, 10:42 AM
Well if it’s still turning over slow from a fully charged car battery, I’d say the starter might just be bad. Unless there’s something wrong internally with the starter gears or motor itself.
Have you been able to start the bike at all?
