Tuxedo Mod Question - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 1 (permalink) Old 04-15-2020, 09:06 AM Thread Starter
Jason Pittenger's Avatar
Tuxedo Mod Question
Since I don't have the proper equipment, I had a shop modify the side plate for me, for the Tuxedo Mod. They left the outside ribs in place, which provides the correct spacing for the Stator. The problem is one of the ribs is not inline with the screw hole, so applying torque to that bolt will warp the new plate.
Should I grind off the ribs and use a different method for spacing?
ID:	47489   Click image for larger version
ID:	47491   Click image for larger version
Completed modifications:
Planned modifications:
Jason Pittenger is online now
