R/R Relocation - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 04-14-2009, 03:52 PM Thread Starter
fartin'martin's Avatar
R/R Relocation
One of the first jobs I want to carry out is the relocation of the reg/rectifier. I have read a lot of advice on how this is carried out and understand the reasons for it.
But has anyone come up with the definitive answer as to whether or not to paint it?
fartin'martin is offline
post #2 of 7 (permalink) Old 04-14-2009, 03:56 PM
Jace Bror's Avatar
That is one of those personal opinion things, I think that it is going to be that much cooler the paint holding in heat is negligable.
Sold 750 (9-09)
Mustand Seat (6-09)
Balanced Carbs (4-09)
Adjusted Mix Screws (4-09)
R/R Relocated (3-09)
Splines Lubed (3-09)
Painted flat blak (3-09)
Kuri grips (8-08)
Kuri Longhorn pegs (8-08)
Iridium Plugs (8-08)
Highway bar/ engine guard(FS)
Facebook ID Eli Gaffke
Jace Bror is offline
post #3 of 7 (permalink) Old 04-14-2009, 03:56 PM
flitecontrol's Avatar
There was a discussion on just this subject a while back. Like almost anything, there were a variety of opinions, but I think it boiled down to the paint having little, if any, affect. Personally, if I wanted to paint it, I would.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #4 of 7 (permalink) Old 04-14-2009, 07:33 PM
I was part of that discussion. What it boiled down to was, clean it as best you can of dirt and acid stains with a wire brush; benchmounted, dremel tool and/or hand held. Buff it if you like. If it`s pretty enough to suit you, mount it. If not, shoot on a couple of light coats of high heat resistant paint. It is probably most efficient bare, but a little paint won`t hurt much. You don`t want gobs and paint runs on it though.
post #5 of 7 (permalink) Old 04-14-2009, 08:09 PM
750Doug's Avatar
I put some paint on mine early last year, and then rode a bunch of miles since. My bike has not burst into flames, crashed, burnt any wires, blown any fuses, over heated, under heated, char-b-qued, electro-statically discharged, melted, cooked, burped, farted, or even smelled funny since.
My carbs give me fits, but I suspect that's simply due to the choice of color I used...but who the hell knows, ya know?
Mine looked worse than dog poo when I pulled it out from under the battery box, but it worked fine, (and still does-knock wood) Cleaning wasn't enough, but a little paint and it blends right in. One of my buddy's thought it was from the factory.
If the paint helps keep the thing warm, then having it exposed to more air flow should help balance that out.
Now, just wait for it.....
750Doug is offline
post #6 of 7 (permalink) Old 04-14-2009, 09:02 PM
CWO3 Navy (Retired)
cliffhusn's Avatar
I de-goated and installed a MF battery, hence, no need to relocate the R&R so I have avoided the paint or not to paint fued that would have been going on in my head. ...Just kidding
...if you remove the reason to relocate then there is no need to do it at all.
The Flag on my bike honors those who serve our Country and those who have served!
cliffhusn is offline
post #7 of 7 (permalink) Old 04-15-2009, 03:42 AM Thread Starter
..if you remove the reason to relocate then there is no need to do it at all.[/QUOTE]
Often, the simplest ideas are the best! I'm all for an easy life!
