My VN 750 is acting strange - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 20 (permalink) Old 04-14-2009, 03:04 AM Thread Starter
Hi,
I went out for a ride yesterday. Never had problems with my bike. But I noticed something when I started her the first time. I had to push the start button twice to get her fired up, like there was not enough power the first time. This happened several times during the day. But the last time, when I was almost home, I couldn't get the bike started anymore. I had to use starting cables and a second battery to start the bike.
The battery is one season old and full with liquid (don't know whats inside). It's not a maintenance free battery. I'm not an expert, but I do want to know what's wrong with my bike. Can someone help me with this? I need a step-by-step guide to check things and how to do it. Maybe it's the stator (still positioned under the battery), but it can also be the dynamo. I really don't know what is wrong.
Willem
gwbosma is offline
post #2 of 20 (permalink) Old 04-14-2009, 03:14 AM
Simple Solutions
seebeeare's Avatar
without further testing im not sure do u have a volt meter? first things first charge your battery... then its time to do a couple quick tests one start bike and hold hand in front of head light when u rev it up does the light get brighter? 2. volt meter across the batt whats the batt volt not running and whats the voltage of the bike when its at idle and when its at 3000 rpm??? a couple more extensive test to come but that should be a good start... did u start with a freshly charged battery? and i do know the not mf batts are lucky to get more then a year out of them ....
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
How To Test the Stator
seebeeare is offline
post #3 of 20 (permalink) Old 04-14-2009, 03:36 AM
The Professor
lance328's Avatar
Originally Posted by gwbosma View Post
Hi,
Willem
Check and clean All battery and ground connections.
Get rid of the battery you have and replace with an AGM MF battery, Link below.
Replace your spark plugs with NGK DPR7EIX-9 #7803 Irridium Plugs!!!
One season is about all you will get from a standard wet cell battery!
Battery
http://cgi.ebay.com/ebaymotors/ws/eB...3AIT&viewitem=
you will recieve in three days.
http://www.batterymart.com/p-Big-Cra..._campaign=Base
They are made by the same company, East Penn Mfg.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #4 of 20 (permalink) Old 04-14-2009, 04:01 AM Thread Starter
I put in the iridium spark plugs last season. Two weeks ago everything was fine and I drove more than 260 kilometers on one day without starting problems. I will try the headlight test this evening. What does this test say when the light gets brighter? I don't know if I can get the mentioned maintenance free battery, because I'm living in Holland. Are there other mf batteries that I can get in Holland suited for the VN750? I now have a Yuasa battery (not mf). When I want a mf Yuasa, what is the right type?
gwbosma is offline
post #5 of 20 (permalink) Old 04-14-2009, 05:09 AM
The Professor
lance328's Avatar
You want a sealed MF AGM battey, here is a link close to home.
http://www.tayna.co.uk/YTXL-BS-Westc...ery-P3386.html
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
post #6 of 20 (permalink) Old 04-14-2009, 12:37 PM Thread Starter
I just started the bike and it fired up without a problem. When I look at the headlight, it gets a tiny bit brighter than when the engine runs idle. I'll buy a volt meter to get some numbers. What does the headlight say?
EDIT: I know have a multimeter and tested the battery. When the engine runs at 3000 rpm, the voltage is 13.5 to 13.7. When the bike is off, the battery volt slowly goes from over 12 volts to lower volts. In about an hour, it gets to below 12 volts (11.80).
gwbosma is offline
post #7 of 20 (permalink) Old 04-14-2009, 08:20 PM
The voltmeter says get a maintenance free- absorbed glass mat battery. A fully charged battery at rest should be at 12 - 12.5volts.
post #8 of 20 (permalink) Old 04-14-2009, 09:14 PM
Love My Baby
rubyrick's Avatar
Your battery at rest should at least be over 12 volts always. My 10-month old battery is typically 12.8 when off, and goes to 13+ when idling, higher at 3000 rpm. Even if things are going well right now, please be smart and buy a glass mat maintenance free battery properly sized for your bike. Then fully charge it prior to installing. Your battery is probably going to die soon. Even if it still has some life to it, you don't want to be stuck somewhere without power.
Rubyrick
MY BABY...
'05 VN750
16,000 miles +
Kawi tank bib
Kawi rear rack
Small windshield
DEKA M/F battery
LED license plate frame
X
rubyrick is offline
post #9 of 20 (permalink) Old 04-14-2009, 09:58 PM
I'd like to put my.02 in on this one if you continue to run tha battery in your bike and it in that low of a state of charge you will be putting an undue amount of work on what is a weak charging system already and could cause R/R or stator failure,It is the old pay now or pay a lot more later problem,they are right buy yourself a new battery, preferably a maintenance free battery and use your old one for the mower or something else we don't need,Denny
post #10 of 20 (permalink) Old 04-15-2009, 02:12 AM Thread Starter
The next morning:
Battery is at 11.74 volt.
To make sure its the battery, is there an other way to check it?
What does the headlight say? Is it good when it shines even a bit when I higher the rpm?
Thanks for all the help!
gwbosma is offline
