Pickup coil wires - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 18 (permalink) Old 01-29-2020, 04:02 PM Thread Starter
Pickup coil wires
Hi, I'm replacing the front pickup coil with this one here:
https://www.regulatorrectifier.com/c...50-pickup-coil
Now this coil has a teal wire and a green wire. The OEM coil has a black wire and a black/yellow wire. I'm planning on splicing the new wires into the existing ones behind the cover as to not need to remove the engine.
Which wire would goes to which? Or does it not matter? Thanks.
rerb is online now
post #2 of 18 (permalink) Old 01-29-2020, 05:21 PM
Think I would try to match it up by the wire position on the stock p/u coil. Trace the original top/bottom wires back to where they connect, then run the top/bottom wires on the new coil to the locations matching the original.
All black/yellow wires on this bike are grounds, but this particular black/yellow could go directly to the CDI.
You might be able to ohm test for continuity between the wires on the new coil and it's mounting plate. It's not foolproof, but if only one wire has continuity to the frame of the coil, there's your black/yellow connection.
Great time to do the pickup coil mod!
post #3 of 18 (permalink) Old 01-29-2020, 09:58 PM Thread Starter
Thanks, I'll try that when it arrives.
And for the mod, what exactly is the .20" gap being set against? I've read the threads about it but I still don't understand what It's being measured from.
Thanks!
rerb is online now
post #4 of 18 (permalink) Old 01-30-2020, 12:04 AM
Thanks!
It's the gap between the face of the p/u coil and the magnet on the rotor.
post #5 of 18 (permalink) Old 01-30-2020, 12:23 PM Thread Starter
Is it possible to check if a wire is good with a multimeter? I ask because after installing the new p/u coil, the signal wire to the ignition coil gets a reading of 23v on my automatic multimeter (battery attached), which is the same as the real ignition coil signal wire, yet the front plugs still don't get spark. Both ignition coils read 1.9 ohms, which is in spec. the 4 pin connector on the ignitor all checks out, but I can't seem to properly test the 6 pin (where the signal wires come from). Could this be a wiring failure or an ignitor failure? or does that measurement on the wire even mean anything? has a ghost possessed my bike?
Thanks.
rerb is online now
post #6 of 18 (permalink) Old 01-30-2020, 12:40 PM
Thanks.
Absolutely the wire can be tested. On a basic meter just use the ohm setting, more advanced meters will have a specific continuity setting, some with an audible test, beeps if there's continuity.
23v huh? Typo .. 13v? What setting are you using on the meter?
I don't believe the CDI/Ignitor can boost voltage, but I'm pretty sure there are tests for it in the manual listed in my signature. There are also ohm tests for the p/u coil. That 6-pin on the Ignitor might involve a diode test, not sure.
I'm not sure there should be voltage on a pickup coil, it's a hall effect sensor if I'm not mistaken, uses the magnetic field on the rotor to trigger the spark at the correct time.
Which color wire are you referring to as the signal wire at the (front) ign coil? I'll try to look at the wiring diagram. Maybe the wires are crossed up?
post #7 of 18 (permalink) Old 01-30-2020, 01:08 PM
A lot of what you said didn't make sense to me. Granted, the ignition system is sort of at the border of my understanding, so maybe I'm mixed up about some things...
What are you touching your leads to when you are reading 23v? Is the bike running (or cranking) when you do this?
I *think* that the CDI provides a signal by switching the dark green (pin 1) and black (pin 4) wires to ground voltage in order to interrupt current from the red wire through the primary winding of the ignition coil, inducing spark via the secondary winding.
As far as I know there shouldn't be 23v anywhere? the green and black wires from the CDI to the ignition coils should be measurable as having 0 ohm on a multimeter.
I also think both spark plugs need to be grounded in order to get either one to spark, so if you're looking for spark by holding just one against the chassis while leaving the other dangling, you'll get no spark. I *think*.
Vulcan slang for newcomers
Service Manual Download
Thorn is offline
post #8 of 18 (permalink) Old 01-31-2020, 09:25 AM Thread Starter
I have a really bad "automatic" $10 autozone multimeter, so it chooses the range for volts. All i know is the black signal wire from pin #4 on the cdi reads "23" on DC current when the positive end is touching the terminal on that wire and the negative is on ground. For ohm testing, should I measure the wire against ground? I'm definitely leaning towards a crossed wire somewhere in the harness. The bike was not cranking during the measurements, but it was connected to the battery.
As far as ohms go, the coil tested good.
The ohm readings on the 4 pin all tested in spec, my multimeter does not display infinity (it just goes to 0) so I can't really guarantee that the 6 pin is in spec. If I can't fix this with a new jumper I will assume bad CDI.
rerb is online now
post #9 of 18 (permalink) Old 01-31-2020, 10:50 AM
Your multimeter should read '0' for a short, and 'OL' for a break/no connection. If it doesn't make that distinction, it's absolutely worthless.
To measure the ohms of a wire, connect one lead to each end of the wire. Putting a lead on ground tells you nothing (unless ground is one end of the wire).
I really can't think of any reason 23v would show up there. Was the ignition switch 'on' and the kill switch 'on'?
Thorn is offline
post #10 of 18 (permalink) Old 01-31-2020, 12:56 PM
Not sure we can trust that meter, reading 23v on the DC setting, I've tossed a few cheap meters. About $25-28 will get a decent one at Lowe's. There's just not that much voltage available. When you said it reads "23" in your last post, I thought maybe it was auto-switching to ohms, but you said it's on the DC setting.
You may be right about the CDI, maybe that's why someone tried to rob signal from the rear coil.
Did the tach work? Black wire off the 4-pin also runs to the tach. All terminals on the 4-pin (cdi) need to read 4-6 ohms.
Need to test the 6-pin @ the cdi too, and there's a wide range of ohm readings shown on the chart in the manual. Infinity, 0.9 to 1.7 ohm, 2 to 4 ohm, 3.6 to 6 ohm, 14 to 26 ohm, and 25 to 50 ohm, depending on the combination of terminals being tested.
If you're testing for continuity on the black wire, you should disconnect the 4-pin cdi plug, make sure the kill switch is set to run, then check between the 4-pin black and the end at the ignition coil.
