stating problem - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 04-12-2009, 06:43 PM Thread Starter
stating problem
My friend gave me a bike .It was flooded in catrina in new orleans.I rebuild the engine and engine is spinning freely.I got me a new set of wires installed.When i try to crank it it makes a clikking noise in the starter rellay,but starter motor does not spin.,if I put a pliers to connect the bolts on the starter relay no click,only clicking when i push the start botton.It is starter or it could be smething else?also i have no electricity on the head lightand the neutral switch control light is not on even when the bike is in neutral i checked the wire(green)and the wire is o.k?Thank for help.I just want to know if the selenoid ould be bad before i remove the starter
maky11 is offline
post #2 of 10 (permalink) Old 04-12-2009, 07:30 PM
Simple Solutions
seebeeare's Avatar
try to jump the starter at the starter run a wire from the positive terminal of the batt to the start or use a batt charger neg to frame pos to starter (MAKE SURE THE BIKE IS IN NEUTRAL )
I'm guessing that its in all the safty switches... and or relay... what is the voltage drop when u push the start button it really sounds like power is not getting to the starter
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
How To Test the Stator
seebeeare is offline
post #3 of 10 (permalink) Old 04-12-2009, 07:54 PM
The Professor
lance328's Avatar
The soleniod contacts could be corroded, check frame , engine and battery ground wires. You starter may be siezed.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #4 of 10 (permalink) Old 04-12-2009, 07:59 PM Thread Starter
yes i tried that and and starter spin over ,so it will be some safety switches I have a manual with wiring diagrams so I will try to go over with that.Thanks for advise.Is there any easy way to bypass the switchess?sorry my english I am from europe
maky11 is offline
post #5 of 10 (permalink) Old 04-12-2009, 08:02 PM Thread Starter
nothing corroded but i found one ground wire not connectet.,the one from engine case.I will have to try tomorrow and will see.Thanks
maky11 is offline
post #6 of 10 (permalink) Old 04-12-2009, 08:10 PM
The Professor
lance328's Avatar
The starter will not turn over without that wire.
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
post #7 of 10 (permalink) Old 04-12-2009, 08:20 PM
Simple Solutions
seebeeare's Avatar
dont quote me on this one but im pretty sure u can jump the wires at the switches to complete the circuit double check your wiring diagrams to make sure... id use paperclips and electrical tape (for testing purposes not for perminant bypassing) .... (not professional i know but should do the trick)
Also without proper grounding its not gonna work... the last thing u want is for large amounts of current to find there way through something its not supposed to
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
post #8 of 10 (permalink) Old 04-12-2009, 08:50 PM
maky, your starter solenoid/relay is clicking when you press the starter button, so the primary or trigger circuit is working. This indicates to me that all the safety switches are engaging properly. Use a test light or voltmeter to test for power at both bolts when you press the start button. If the relay clicks but you still only have power at the bolt nearest the battery, then the relay is faulty.
When you use the pliers to connect the two bolts, you jump across the relay and bypass the electric switch that makes the clicking noise. The starter should try to turn over when jumping across the relay like this. If it doesn`t, then either there is a poor ground connection, starter connection or the starter itself is faulty. Make sure the ground cable from battery to frame connections are clean and tight, and any other ground connections too.
Try seebeeare`s suggestion to jumpstart directly to the positive post on the starter itself. If you still do not get the starter to try to turn over, the next step is to remove it for a bench test and and diagnosis.
Let us know what you learn from trying these tests. Good luck.
post #9 of 10 (permalink) Old 04-12-2009, 09:19 PM
The Professor
lance328's Avatar
He already found the problem, he did not hook up the engine ground. That is why I suggested he check his grounds.
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
post #10 of 10 (permalink) Old 04-13-2009, 05:24 PM Thread Starter
its amaizing what ground cable can do !!I I have spark and my starter spin like crazy...Thanks Guys
maky11 is offline
