Headlight Visor - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 04-12-2009, 09:34 AM Thread Starter
yacovi99
Headlight Visor
I want to purchase the k53020-120 headlight visor. Do you need to take apart the entire headlight assembly to install the visor?? Could not find instructions on google.
Thanks...
Vyacovett is offline
post #2 of 3 (permalink) Old 04-12-2009, 10:55 AM
dirtrack650's Avatar
I picked one up from JC Whitney. On that visor, I had to remove the headlight from the headlamp ring, place a lip of the visor between the ring and the headlamp, then tighten things back up. Not too hard to do at all, but you do need to aim the headlamp when done. I've had mine on for quite a while with no problems.
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #3 of 3 (permalink) Old 04-12-2009, 03:41 PM
CWO3 Navy (Retired)
cliffhusn's Avatar
I put one on and did not have to take the headlight apart. It snapped in just fine. You'll need to put a bead of clear silcone on the inside between the visor and the headlight housing.
The Flag on my bike honors those who serve our Country and those who have served!
cliffhusn is offline
