Aftermarket Ignition Coils - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 1Likes
post #1 of 12 (permalink) Old 09-23-2019, 10:12 AM Thread Starter
Jason Pittenger's Avatar
Any recommendations? I suspect my coils are failing. I might be jumping the gun, but are there aftermarket coils that people have used and recommended?
Completed modifications:
Planned modifications:
Jason Pittenger is offline
post #2 of 12 (permalink) Old 09-30-2019, 06:17 PM
I have a used oem that I'll sell to you. I thought I needed it when I lost power to a cylinder but it was a grounded pickup coil
Chris Allunario is offline
post #3 of 12 (permalink) Old 09-30-2019, 06:21 PM
I've seen one set of performance coils since I began shopping VN parts, they were on ebay.
In the old days I ran automotive performance coils on bikes with points type ignition. Those might work on the VN, they all work on the same principle, and connect the same way.
post #4 of 12 (permalink) Old 09-30-2019, 08:56 PM
Location: Southern Maryland, Waldorf/LaPlata/Indian Head area
I would do the 12 volt coil mod also. That should help with the hot starts.
1985 700 Vulcan / Purchased 13,636 miles currently 19,126/Fork Seals & Dust Covers/Ignition Switch/AGM Battery/Hell Fire Windshield/River Roads Saddle Bags/Coil Relay Mod/2Wire Mod/RLU Bypass/Head Light Switch/Voltage monitor Green light/Mosfit R&R/Tuxedo Mod/Stator/Point Gap .020/ Dampers/Rear Signal & Brake Light LED'S/Rebuilt Shutoff Valve/Final Drive Gear Oil/Brake Shoes/Spline & Hub Lube/11 inch Progressive Shocks/De Goated/Engine Guard/Rejetted For K/N Pods/TOC mcct's
Sparkys73150 is offline
post #5 of 12 (permalink) Old 10-01-2019, 12:29 PM Thread Starter
I'm not familiar with this mod?
post #6 of 12 (permalink) Old 10-01-2019, 02:24 PM
Originally Posted by Jason Pittenger View Post
I'm not families with this mod?
https://www.vn750.com/forum/19-elect...lay-mod-6.html
post #7 of 12 (permalink) Old 10-01-2019, 06:24 PM
Just had a thought ... Using automotive ign coils means four coils to mount and wire up.
Looks like there are plenty of twin lead coils available, just have to shop for a good price, $180 for the one I looked at is pretty steep.
http://www.vmxunlimited.com/ignition...ad-2-terminal/
Where to put four of these?
post #8 of 12 (permalink) Old 10-02-2019, 09:52 AM Thread Starter
Thanks! I'll measure my primary voltage.
What do you think about these?
https://www.amazon.com/Dynatek-Coil-.../dp/B005G5RDTU
Primary 2.2 ohms (Stock coils are 1.8-2.2)
Secondary 14,000 ohms (Stock coils 19-29k)
Seems close enough, though the secondary is below spec.
Do you have just one, or a pair available?
post #9 of 12 (permalink) Old 10-02-2019, 12:19 PM
I thought the tests on your coils, hot/cold, looked ok.
CDi maybe? Just not sure.
Might not hurt to observe carb slide action, hot/cold.
post #10 of 12 (permalink) Old 10-02-2019, 05:03 PM Thread Starter
I didn't have time to measure cold this morning, but hot measurements seem fine. However, I just noticed in the manual that the measurements are supposed to include the plug wires! I measured at the coil itself.
Let's say it is the slides. What would be the fix? I suspect the fix would be spraying some lubricant on them? That'd be something cheap to try, even if it wasn't the problem.
Either way, I've heard the stock ignition is only adequate. Even if the coils are good, I might upgrade. I'm still thinking about bumping the timing up to the max allowed in the manual. It states 5 at idle, but the chart shows a range of (4-6 or 4-7).
