Blinker Question - Page 2 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #11 of 27 (permalink) Old 09-11-2019, 12:22 PM
mmart's Avatar
And like I said they’re pricey but they come with bulbs, I didn’t expect that
mmart is online now
post #12 of 27 (permalink) Old 09-11-2019, 03:37 PM
mmart's Avatar
Here’s the part number
23037-1220 - LAMP-ASSY
Again this is for the rear
mmart is online now
post #13 of 27 (permalink) Old 09-11-2019, 03:42 PM Thread Starter
thanks, I will be getting them from there! I found both part items Front # 23037-1214 Rear # 23037-1220
xirnibor is offline
post #14 of 27 (permalink) Old 09-11-2019, 09:19 PM Thread Starter
My next obvious question. Where do the connectors "connect". Below the seat? Under the headlight? How much do I need to take apart?
xirnibor is offline
post #15 of 27 (permalink) Old 09-11-2019, 09:33 PM
Inside the headlight housing.
post #16 of 27 (permalink) Old 09-11-2019, 09:47 PM
mmart's Avatar
Take the seat off for the rear set, you’ll see the wiring towards the back above the rear fender. The wires have black jacketing on them for weatherproofing.
mmart is online now
post #17 of 27 (permalink) Old 09-11-2019, 10:41 PM Thread Starter
Is it just the one screw to remove the cover, or all 3? See pics. Looking at it from the front, Two on the left side, one on the right
ID:	46557   Click image for larger version
xirnibor is offline
post #18 of 27 (permalink) Old 09-11-2019, 10:48 PM
All three if I recall. The one holds the trim ring to the shell, then the other two hold the reflector in the shell.
post #19 of 27 (permalink) Old 09-11-2019, 10:51 PM Thread Starter
So is it the actual bulb I turn to the 2 o'clock position for removal? Trying to figure this out. Thanks for the replies
xirnibor is offline
post #20 of 27 (permalink) Old 09-11-2019, 10:57 PM
mmart's Avatar
All three if I recall. The one holds the trim ring, then the other two hold the reflector in the shell.
Thought it was just the two to loosen the bucket and the 3rd (more forward pointing) is to adjust the lamp angle. There’s a spring and small plastic piece behind that. Nothing major just warning you so it doesn’t pop out on you. I made that mistake and it took me 15min to find that “thing” I dropped. I had no idea what I was looking for until I found it lol.
Here’s a pic when I upgraded my headlight bulb
mmart is online now
