MIGHT have to cut stator wires... Please advise - Page 3 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 1Likes
post #21 of 22 (permalink) Old 08-23-2019, 01:30 PM
Originally Posted by Dokuji View Post
ok thank you. It doesnt actually seal any oil does it? the oil should be within the actual stator housing right? so i assume this outer seal is just for a bit of air pressure retainment?
Yes, it seals oil. No real pressure, but accumulating splash off the rotor. Will leak if it doesn't seal. I reused all the o-rings on my cover, just put a very light coating of sealer on the perimeter o-ring gasket.
I'm wondering if it might be possible to slide the stator case out far enough to install a grommet? I'm thinking it might, but don't remember if there's any interference getting all the bolts out. Need to hobble out and look at my bike, it hasn't moved this summer.
roadpouring likes this.
post #22 of 22 (permalink) Old 08-27-2019, 07:37 PM
pcdj64's Avatar
Can you put some black ATV around the JB weld where the leak is?
It might not be real pretty but it it is a small leak the ATV will seal it.
pcdj64 is offline
