VN750 voltage regulator issues - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 2 (permalink) Old 08-05-2019, 12:35 AM Thread Starter
I have been going thru a number of voltage regulater replacment. 3 in the last year. Once changed voltage at 4k is between 14 - 15 as it should be. Then all of a sudden my bike dies, battery not being charged. Go home and fully charge battery. Either voltage at 4k is less than 14 or voltage at 4k is 16+. I installed a separate voltage led to monitor charging voltage as I ride. Any ideas out there. I do purchase non-oem regulators. OEM regulator from Kawaskai are not cheap. VR is a simple circuit. Any insight would be appreciated.
Mike T,
met1532 is offline
post #2 of 2 (permalink) Old 08-05-2019, 08:00 AM
mmart's Avatar
Have you checked the stator? If you replaced 3 R/Rs already because of the same issue, that leads me to believe you have a separate problem
mmart is online now
