Aftermarket Incandescent Lights - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 6Likes
post #1 of 28 (permalink) Old 07-07-2019, 07:41 PM Thread Starter
Hey all, I'm having an issue trying to get 2 pairs of aftermarket lights running all at once. I had them on the front with stock lights on the back for a couple weeks, and now I finally took the jump today and installed the rear lights too. When I was running the bike with just one new pair, I noticed that my bike had the "hyper flash" issue, it didn't bother me, but now that I decided I wanted these things to match, I've opened the next can of worms. The store page claims that these are non-LED lights.
I made a video for you, I ramble a bit sorry about that. I do intend on replacing the wire butts with some smaller ones, I was just testing the lights out with them. I regret not splicing the "blades" on for both wire setups, an unfortunate mistake on my part there.
The lights I purchased - https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Ty Gauthier is offline
post #2 of 28 (permalink) Old 07-07-2019, 08:49 PM
mmart's Avatar
Even if they’re not LED they may still run less juice than stock and you’ll either need a different relay to even out the pulse or you’ll need load resisters in line with the bulbs. That’s the basic fix with aftermarket lights. Why your lights are dimming I’m not 100% sure.
mmart is online now
post #3 of 28 (permalink) Old 07-07-2019, 09:04 PM Thread Starter
Hey thanks for the quick reply. Any chance you can point me in the direction of a relay that will work for me?
post #4 of 28 (permalink) Old 07-07-2019, 09:16 PM
mmart's Avatar
Honestly I haven’t looked into it personally. I changed my headlight and tail/brake lights to led but left the signals alone. But it’s as easy as “vn750 flasher relay” in google and before you know it you’ll have too many to choose from lol. Im hesitant that you stated that the new lights aren’t LED though. Somebody who’s lived it will chime in.
Ron Ryman likes this.
mmart is online now
post #5 of 28 (permalink) Old 07-07-2019, 11:36 PM
I think maybe the front bulbs are installed backward (depending on the type of bulb) or the wires are connected wrong. It looks like the brights are on all the time, and the lows are on the flasher side.
Don't know if that fixes the flasher or not. EP34 is the flasher for LED, and it works with all bulbs.
post #6 of 28 (permalink) Old 07-08-2019, 06:02 AM Thread Starter
I don't know if they're backwards, they worked just fine before I installed these new rear ones. All of the lights are 2 wire, even though the front signals used to be 3 wire. I noticed they had hyper flash before I installed the new ones now I have no flash.
post #7 of 28 (permalink) Old 07-08-2019, 07:56 AM
mmart's Avatar
Ok that’s starting to make sense. The original were 3 wire because they share a common ground and one leg was for the running lights and the other leg was for the flashers. (One bulb, 2 filaments) The hyper-flash is due to the new bulbs not requiring as much juice as the stock bulbs and it throws off the electronics components a bit. But it’s starting to sound like you have two separate issues here
MSattler likes this.
mmart is online now
post #8 of 28 (permalink) Old 07-08-2019, 07:59 AM
mmart's Avatar
How did you wire them in??
mmart is online now
post #9 of 28 (permalink) Old 07-08-2019, 08:02 AM
Ahhh, new info. I have no idea.
Do the new lights have double filaments?
post #10 of 28 (permalink) Old 07-08-2019, 08:11 AM
2003 Vulcan 750/Sidecar
Hench's Avatar
According to the reviews on Amazon they're single element bulbs like an 1156. Blinkers only no running lights.
2003 VN750
Velorex 562 sidecar w/trunk
2-wire mod
Headlight power switch
Manual fan switch
Shingigen SH775
Blue wire mod
Yellow wire mod
RLU removed
RR moved
Voltmeter relay wired
Coils direct wired w/relay
handicap mods:
extended foot shift
heel shifter
extended brake pedal
Hench is offline
Tags
wiring signals trouble
