Aftermarket Incandescent Lights - Page 2 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 6Likes
post #11 of 28 (permalink) Old 07-08-2019, 08:23 AM
Originally Posted by Hench View Post
According to the reviews on Amazon they're single element bulbs like an 1156. Blinkers only no running lights.
There's the problem, if that's the case.
post #12 of 28 (permalink) Old 07-08-2019, 08:28 AM
2003 Vulcan 750/Sidecar
Hench's Avatar
Ty
Did you by any chance connect the running light positive also to the fronts?
MSattler likes this.
2003 VN750
Velorex 562 sidecar w/trunk
2-wire mod
Headlight power switch
Manual fan switch
Shingigen SH775
Blue wire mod
Yellow wire mod
RLU removed
RR moved
Voltmeter relay wired
Coils direct wired w/relay
handicap mods:
extended foot shift
heel shifter
extended brake pedal
Hench is offline
post #13 of 28 (permalink) Old 07-08-2019, 08:40 AM
I just browsed through the Amazon link you sent. If you scroll down it states that they’re flashers only and not to be used for daytime running lights. So back to the wiring, if you hooked up all 3 wires something is shorting depending on switch position, that’s why the front are basically turning off when you turn on your signal. Also I noticed in your video that your signal indicators are constantly on, that’s not normal. They should flash with the signals. So you can either remove the running light lead as use them as flashers only, or replace the front pair. Again the relay is for the flash rate and will not fix both issues.
mmart is online now
post #14 of 28 (permalink) Old 07-08-2019, 09:09 AM Thread Starter
That must be it! Let me get you a picture of the front light wiring. I thought it was weird that the front lights were on despite them not being useable for running lights.
Ty Gauthier is offline
post #15 of 28 (permalink) Old 07-08-2019, 09:15 AM Thread Starter
What do I do with the running light wires if they aren't connected to anything? Splice them together?
post #16 of 28 (permalink) Old 07-08-2019, 09:22 AM
Hench's Avatar
Electrical tape on exposed ends of running light wires to prevent shorts. Don't tie them together.
2003 VN750
2-wire mod
Manual fan switch
Shingigen SH775
Blue wire mod
Yellow wire mod
RLU removed
RR moved
handicap mods:
extended foot shift
heel shifter
Hench is offline
post #17 of 28 (permalink) Old 07-08-2019, 10:09 AM
Yeah what he said!
mmart is online now
post #18 of 28 (permalink) Old 07-08-2019, 12:28 PM Thread Starter
Took a look at the bike on break. I got the wiring fixed up. The front and back signals now both light up solid. I might still need that relay.
post #19 of 28 (permalink) Old 07-08-2019, 01:07 PM
Hench's Avatar
One review said the bulbs are low amps. Probably need the relay Spockster listed. They also said these bulbs burn out quick and aren't true 1156. Might start looking for replacements!
2003 VN750
2-wire mod
Manual fan switch
Shingigen SH775
Blue wire mod
Yellow wire mod
RLU removed
RR moved
handicap mods:
extended foot shift
heel shifter
Hench is offline
post #20 of 28 (permalink) Old 07-08-2019, 01:21 PM
Somebody correct me if I’m wrong. But I thought only the front were running lights and always lit. Thought the rear only flashed when the signal is on. I never bothered to notice haha
mmart is online now
Tags
wiring signals trouble
