Bike dies when turning handle bars to the right - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 3Likes
post #1 of 25 (permalink) Old 07-06-2019, 08:41 AM Thread Starter
MSattler's Avatar
I had posted this originally in the engine forum, but it is electrical. The back story is that the bike would die whenever I turned the handlebars to the right. Several people suggested to check the left side wiring harnesses (makes complete sense, as it is adding strain there when turning left). I could not get the problem to duplicate yesterday, in the 95 degree heat, but I got it this morning when it was 70. Maybe the harness was more pliable yesterday in the heat. I have taken a video of the issue, and it has a relay like click when I get to the “dead zone”. Maybe kill switch? Maybe ignition? You’ll need audio for this, but it has a distinct relay sound coming from the right side of the bike. If the video doesn’t have sound for you, click the “v” in the lower left side of the video. It’ll take you to the page
'08 Road King Classic
'86 VN750:
Ear Shave, K&N Filters, Mean Streak Seat, AGM battery, Blue Wire Mod, Pick-up Coil Mod, Timing Advance Mod, NGK Iridium Plugs and Wire, LEDs, Bed Liner Paint Job, Over-sized Tires, New Brakes, New Fork Seals, Progressive Springs, Kick Stand Mod, Highway Pegs, 40/140 No Shims, Vance & Hines Exhaust, New Grips, Extra Wide Emgo Handle Bars
John 8:44, REV 2:9, REV 3:9 - If you were kicked out of 109 bars, would you think the problem was you, or the 109 bars?
MSattler is online now
post #2 of 25 (permalink) Old 07-06-2019, 09:11 AM
2003 Vulcan 750/Sidecar
Hench's Avatar
Where is the relay for your coil mod? Is that it by the battery? Are the terminals fully insulated? No bare metal on the connections or pins?
2003 VN750
Velorex 562 sidecar w/trunk
2-wire mod
Headlight power switch
Manual fan switch
Shingigen SH775
Blue wire mod
Yellow wire mod
RLU removed
RR moved
Voltmeter relay wired
Coils direct wired w/relay
handicap mods:
extended foot shift
heel shifter
extended brake pedal
Hench is offline
post #3 of 25 (permalink) Old 07-06-2019, 09:24 AM Thread Starter
MSattler's Avatar
That is it by the battery. Where you have the washers and the bolt. They are not fully insulated, just the female connectors attached to the pin. I caught a sheet metal screw in the front tire, and I was going to get a patch kit from O’Reillys. I can get some heat shrink there. It sounds identical to the relay that turns on when the ignition is turned on. So that would make sense, since the rear coil is the trigger. To test, I should be able to disconnect the trigger from the relay to see if that is it.
Update - I pulled off the trigger and sure enough, it stopped doing that. So... is it as simple as insulating the female connectors? I just filled the tank, and I do not feel like draining it for the umpteenth time. I have a new petcock kit coming, so I will clean the fuel gauge, run new wire and see if that will fix that gremlin.
'86 VN750:
post #4 of 25 (permalink) Old 07-06-2019, 09:32 AM
Hench's Avatar
Insulate the terminals by wrapping electrical tape around them and the relay. If the relay is loose and the bike only shuts off going up/down hill as you said in your previous thread the relay may be swinging and shorting against the frame.
2003 VN750
2-wire mod
Manual fan switch
Shingigen SH775
Blue wire mod
Yellow wire mod
RLU removed
RR moved
handicap mods:
extended foot shift
heel shifter
Hench is offline
post #5 of 25 (permalink) Old 07-06-2019, 10:12 AM Thread Starter
MSattler's Avatar
I will do that. The relay is tight though, and it felt like it would break if I pushed on it much harder to move it. It shuts off when turning the handle bars. So I think something is being stretched and grounding out.
'86 VN750:
post #6 of 25 (permalink) Old 07-06-2019, 10:24 AM
Hench's Avatar
If the relay pins are exposed it might not take much movement to short it open. Wrap it and try it.
If no improvement, back to the wiring under the neck covers. You mentioned corroded wires. It may be you have a wire that is broken in the insulation and not visible as exposed. When you turn right it pulls apart in the insulation.
2003 VN750
2-wire mod
Manual fan switch
Shingigen SH775
Blue wire mod
Yellow wire mod
RLU removed
RR moved
handicap mods:
extended foot shift
heel shifter
Hench is offline
post #7 of 25 (permalink) Old 07-06-2019, 02:30 PM Thread Starter
MSattler's Avatar
It is grounding out the starter. The button does nothing after the relay clicks. I have insulated the whole mod very with electrical tape, but nothing works. The battery jumps up to 14vdc on idle and then drops to like 13.5 at 4K rpm. Thoughts? I have the stock r/r
'86 VN750:
post #8 of 25 (permalink) Old 07-06-2019, 03:04 PM
Hench's Avatar
Working from faulty memory here. I think the coil wiring shows connecting the positive coil wire to the relay and on to the coils as connected to the starter relay positive. Try connecting that wire directly to the battery. Leave the relay trigger wires as is.
14v at idle when just started RR may be recovering the battery and then reving it is clipping voltage to a lower charging rate. If you battery shows 12.8V after sitting idle for 24 hours I wouldn't worry about stator/rr for now. Let's find the starting problem for now.
BTW, is the RR still under the battery box?
2003 VN750
2-wire mod
Manual fan switch
Shingigen SH775
Blue wire mod
Yellow wire mod
RLU removed
RR moved
handicap mods:
extended foot shift
heel shifter
Hench is offline
post #9 of 25 (permalink) Old 07-06-2019, 04:27 PM Thread Starter
MSattler's Avatar
Yes it is still in the stock location. I have the red wire that connects the two coils wired directly to the battery. That was the mistake I made before, I had it grounded
'86 VN750:
post #10 of 25 (permalink) Old 07-06-2019, 06:38 PM
Hench's Avatar
About the battery voltages are those readings from when the bike would start?
Is the not starting intermittent or solid failure now?
Have you checked the battery voltage after sitting for a couple of hours. If so what was it? You have a wet cell battery if I recall correctly.
2003 VN750
2-wire mod
Manual fan switch
Shingigen SH775
Blue wire mod
Yellow wire mod
RLU removed
RR moved
handicap mods:
extended foot shift
heel shifter
Hench is offline
