Starting problem - Page 2 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 10Likes
post #11 of 27 (permalink) Old 06-30-2019, 10:08 AM Thread Starter
Starting problem
I have a cheap wet cell. I will replace it soon though. So I got the new relay, and it is not clicking now. Hereís the three wire splice. One to the front coil, one to the rear coil and the third wire to the relay. I am using 12ga wire.
Hereís the relay. The orange wire is the inline fuse with a 15 amp mini breaker. Black is ground to the left side 10 pin bracket bolt. The bottom red one is the stock coil wire. Am I missing something here?
*edit*
Anecdotal, but the front coil red wire is positive, as is the back coil, when ignition is on. Yet, the new wires are not positive, rather they are ground. Thus, the coils are getting two negatives, which wouldnít make them crank. Iíve checked the wiring about 5 times, so I am confused as to what is going on here
'08 Road King Classic
'86 VN750 with the following work done to it, after sitting for 19 years:
  • Blue Wire Mod
  • Two Wire Mod
  • Coil Mod
  • 2nd Coil Mod
  • Ear Shave
  • 42/142 Jets
  • Debadged
  • Rattle Can Flat Paint
  • Exhaust Coming
  • K&N Filters
  • Carbs Cleaned
  • Petcock Rebuilt (unsucessfully)
  • Coolant Flushed
  • Rear Spline Lube
REV 2:9
www.voat.co
MSattler is offline
post #12 of 27 (permalink) Old 06-30-2019, 10:26 AM Thread Starter
Originally Posted by Hench View Post
Thanks!
A new AGM. iridium plugs and the coil mod cured my hot starting issues. Look at Spockster's 2 wire mod. Cured some other problems I had.
Well, after this is solved! :~)
So far I have done the two wire mod, and the blue wire mod, thanks to Spockster. I have the ear shave mod, 42/142 jets (I found a nice man who wants to trade the stock exhaust for a Vance and Hines set. No way I could say no, so those will be going on in a couple of weeks), and I plan on doing the coil mod that UberTallDude sent me with the .20 depth. I would like to make this my daily rider bike (keep the miles off of the other one), but this is killing me.
  • Blue Wire Mod
  • Two Wire Mod
  • Coil Mod
  • 2nd Coil Mod
  • Ear Shave
  • 42/142 Jets
  • Debadged
  • Exhaust Coming
  • K&N Filters
  • Carbs Cleaned
  • Coolant Flushed
  • Rear Spline Lube
REV 2:9
www.voat.co
MSattler is offline
post #13 of 27 (permalink) Old 06-30-2019, 10:49 AM
2003 Vulcan 750/Sidecar
Hench's Avatar
check wire location on relay.
trigger positive to relay 85, trigger negative to 86, battery positive to 36/30, coil positive to 87. Check the fuse.
Try using a jumper from another switched positive instead of the original coil wire. Maybe the switched accessory positive under the right side cover. I used the one in the headlight bucket.
MSattler likes this.
2003 VN750
Velorex 562 sidecar w/trunk
2-wire mod
Headlight power switch
Manual fan switch
Shingigen SH775
Blue wire mod
Yellow wire mod
RLU removed
RR moved
Voltmeter relay wired
Coils direct wired w/relay
handicap mods:
extended foot shift
heel shifter
extended brake pedal
Hench is online now
post #14 of 27 (permalink) Old 06-30-2019, 12:21 PM
It's hard to switch back and forth from the diagram, and orient the relay in the pic, ... but .. It looks like the trigger +, and + to the coils might be reversed.
edit: See if terminals 86 and 87 need reversed.
86 should be trigger +
87 should be + to coils
post #15 of 27 (permalink) Old 06-30-2019, 12:37 PM Thread Starter
Starting problem
I donít get it. I have the two coils on pin 87, the old coil positive on 86, the inline fuse on 85 and the chassis ground on 30. 87, 85 and 30 are all negative.
So it is negative with the ignition turned... so when the relay closes, it is completing the circuit for ground. I have to have something backwards
  • Blue Wire Mod
  • Two Wire Mod
  • Coil Mod
  • 2nd Coil Mod
  • Ear Shave
  • 42/142 Jets
  • Debadged
  • Exhaust Coming
  • K&N Filters
  • Carbs Cleaned
  • Coolant Flushed
  • Rear Spline Lube
REV 2:9
www.voat.co
MSattler is offline
post #16 of 27 (permalink) Old 06-30-2019, 12:45 PM
Originally Posted by MSattler View Post
I don’t get it. I have the two coils on pin 87, the old coil positive on 86, the inline fuse on 85 and the chassis ground on 30. 87, 85 and 30 are all negative.
Now it looks like you have the inline fuse on a ..Ground - terminal 85?
Terminal 36 in the diagram is fused power from the battery cable.
If you're supplying the main power to the relay from the old ignition wiring, the mod is only as good as the stock wiring. So if you had a problem there, it's still there.
post #17 of 27 (permalink) Old 06-30-2019, 01:16 PM Thread Starter
Starting problem
I am an idiot. The inline fuse goes to positive. I am glad this post is here to capture my blonde moment.
  • Blue Wire Mod
  • Two Wire Mod
  • Coil Mod
  • 2nd Coil Mod
  • Ear Shave
  • 42/142 Jets
  • Debadged
  • Exhaust Coming
  • K&N Filters
  • Carbs Cleaned
  • Coolant Flushed
  • Rear Spline Lube
REV 2:9
www.voat.co
MSattler is offline
post #18 of 27 (permalink) Old 06-30-2019, 01:33 PM
Talking
It happens. Was starting to think I was cracking up though.
Swap them around and see where the wire on terminal 30/36 is coming from.
I would unscrew those battery caps and see if any cells are dry.
Hench did it posting that diagram.
post #19 of 27 (permalink) Old 06-30-2019, 01:37 PM Thread Starter
Starting problem
I now have three positives. The power to the two coils on 87 is now positive, 86 is the trigger from the old rear coil, 30 is hooked straight to the.l battery positive, and 85 is going to the chassis connected to the bolt top left bolt above the JB.
I got shocked by the spark plug boot, so all is well. I canít try out the bike though:
  • Blue Wire Mod
  • Two Wire Mod
  • Coil Mod
  • 2nd Coil Mod
  • Ear Shave
  • 42/142 Jets
  • Debadged
  • Exhaust Coming
  • K&N Filters
  • Carbs Cleaned
  • Coolant Flushed
  • Rear Spline Lube
REV 2:9
www.voat.co
MSattler is offline
post #20 of 27 (permalink) Old 06-30-2019, 02:17 PM
Hench's Avatar
Stepped away for a bit. Glad to see it's fixed! Good job, guys!
Paint is looking good! Clearcoat or flat finish?
I'm back to finishing the solar for the sidecar! :~)
2003 VN750
2-wire mod
Manual fan switch
Shingigen SH775
Blue wire mod
Yellow wire mod
RLU removed
RR moved
handicap mods:
extended foot shift
heel shifter
Hench is online now
