2 Wire Aftermarket signals as running lights? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 06-16-2019, 08:24 PM Thread Starter
Hey everyone. Today I had to replace my old rotted out front signals. I grabbed some cheap replacements online only to realize that they only had 2 wires coming off them. I don't have running lights, speedometer lights, or a rear light on my bike anymore with these things installed! Did I screw something up wiring? Is there some kind of conversion I can do to make these work or am I screwed into having to buy new signals? Thanks a bunch.
https://www.amazon.com/gp/aw/d/B07G9...b_b_asin_title
Ty Gauthier is offline
post #2 of 3 (permalink) Old 06-17-2019, 07:52 AM
NewB to Vulcans
TonyO's Avatar
Yes you screwed up! No there is no common conversion.
Depending on your state you may not need running lights at all and i doubt very much you would get pulled over for just that.
Just disconnecting the front running lights should not have affected anything else adversely. Check the fuse.
'99 Vulcan "Victoria"
TonyO is offline
post #3 of 3 (permalink) Old 06-19-2019, 11:44 AM
You should be able to connect just the gray and black/yellow wires to your new turn signals, as long as you don't need running lights. The blue wire should be disconnected and properly insulated on the end to prevent an accidental short. You may have blown the 'headlight fuse' if your speedometer and tail light are out. Do you have the blue wire mod done already? Does your headlight work?
Vulcan slang for newcomers
Service Manual Download
Thorn is offline
