Charging issue - Page 2 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #11 of 28 (permalink) Old 06-15-2019, 10:22 AM
Here's the pin diagram from the manual, the monitor (sense) wire is between the the positive and ground. Monitor wire is brown, if I recall.
Link to repair manual download, just in case you need it: http://www.mediafire.com/file/mj7z81..._Catalogue.pdf
R/R Pin Diagram
Can't get it to display, try this link: http://image.wikifoundry.com/image/1...4167/GW618H800
post #12 of 28 (permalink) Old 06-16-2019, 09:37 AM
NewB to Vulcans
TonyO's Avatar
Was the replacement R/R an original or MOSFET part?
'99 Vulcan "Victoria"
TonyO is online now
post #13 of 28 (permalink) Old 06-16-2019, 01:25 PM Thread Starter
The replacement was a ricks electric. I spoke with a friend who says if it’s supposed to be infitinity resistance and I’m getting 6.5 m ohms that is too low a number compared to infinity. Conveniently I looked up the part and I have a zn700ltd from 85 and it’s the same regulator. Going to try that all the grounds and plugs are good and clean. I can’t say the wires are not corroded inside but nothing is getting warm or hot as I’d expect if it was shorting to ground.
N01290088 is offline
post #14 of 28 (permalink) Old 06-16-2019, 02:36 PM
That chart in the manual can be a bit confusing. Are you sure you checked the terminals correctly?
Some terminals should be infinity, others range from 10k, 0.4 to 2k, 1 to 5k, and 0.2 to 0.6k.
post #15 of 28 (permalink) Old 06-17-2019, 11:42 AM Thread Starter
Yes I believe I followed the chart correctly in my testing. I can check again to be sure
post #16 of 28 (permalink) Old 06-22-2019, 09:50 AM Thread Starter
So I tested the regulator with it out of the bike and did not get the tests to come up as the chart indicated. Said yay new regulator. Tried the resistance chart with new one got extremely similar numbers to the replacement. Plugged in new regulator exact same conditions 13.1-2 volts at 1500 rpm. It drops to 12.95 at 3000.
What are the chances of two new replacement regulators being bad? Or am I right to assume this is elsewhere in the wiring. As stated earlier the resistance test and voltage test of the stator were in spec.
post #17 of 28 (permalink) Old 06-22-2019, 10:01 AM Thread Starter
Just tested a new idea. Rechecked the stator it’s still infinity to ground at the plugs on stator end. I checked the resistance of the wires from the harness. I have infinity on 2 of three and 12m ohms on the a3 wire at both ends when I just do continuity between both ends I have .1 ohms the other 2 just read zero. Is there any reason a single wire would be different other than a short in harness?
post #18 of 28 (permalink) Old 06-22-2019, 10:54 AM
The two wires with infinity are broken?
edit: >>> Somebody check me on this. Thorn, Tony, MTB .. anyone. I've struggled with the definition of 'infinity' in this sense lately.
Experts say infinity to ground on a stator test is good. Meaning no connection to ground.
So infinity on the wire test means no connection?
My Meter only shows OL, Open Loop, have not seen ∞ , the infinity symbol.
post #19 of 28 (permalink) Old 06-22-2019, 11:04 AM Thread Starter
Ok last thing. I cut the battery wire and negative and wired with a same piece of wire directly to the battery. Perfect 12.5 volts at 1000 13 volts at 1500, and 14.2 at 2500 and up. Can I just wire this like this with a more permanent situation (thicker wires with round hooks currently I just have a wire spliced on with it wrapped around the battery to test it)
post #20 of 28 (permalink) Old 06-22-2019, 11:12 AM
Yes, should be fine. If it's the wires from the R/R, you're bypassing the JB and the wiring harness, Both can be problems.
