Where do I get power from? IGN - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 04-05-2009, 09:57 PM Thread Starter
Intelligent Redneck
kennyw's Avatar
I am installing my heated grips. Haven't had a chance to look through the wiring diagrams yet, but I am looking for an ignition circuit to switch the relay from.
kennyw is offline
post #2 of 9 (permalink) Old 04-05-2009, 10:02 PM
I think that you can use your head light wire for the relay. And come right off the bat for the load lead.
post #3 of 9 (permalink) Old 04-05-2009, 10:13 PM
The Professor
lance328's Avatar
Pull switch power from one of the front running lights and main power from the accessory leads in the H.L. bucket, one is - and the other is +. You can keep the relay in the bucket.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #4 of 9 (permalink) Old 04-05-2009, 10:54 PM Thread Starter
Intelligent Redneck
kennyw's Avatar
I'm looking for something back near the battery though... My relay came as part of a pre-made harness and has a short lead to connect the main power.
kennyw is offline
post #5 of 9 (permalink) Old 04-05-2009, 10:56 PM Thread Starter
Intelligent Redneck
kennyw's Avatar
I'm making good progress though. Grips are on, controller is mounted and I'm buttoning up the last of the wiring.
kennyw is offline
post #6 of 9 (permalink) Old 04-05-2009, 11:04 PM
The Professor
lance328's Avatar
You can pull switch power from one of the two red wires under the seat that goes to the tail/tag lights.
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
post #7 of 9 (permalink) Old 04-05-2009, 11:30 PM Thread Starter
Intelligent Redneck
kennyw's Avatar
Thanks, two more connections and I'll be done... I love having a computer in my garage for quick help while I'm in the middle of working on something.
kennyw is offline
post #8 of 9 (permalink) Old 04-06-2009, 05:58 AM
750Doug's Avatar
MF battery next on the list?
750Doug is offline
post #9 of 9 (permalink) Old 04-06-2009, 10:10 PM
cglennon's Avatar
It looks like an Eastern Beaver custom harness. I used one with my heated grips, great workmanship and you can't beat the Posi-Lock connectors. I wired my relay energizer wire to the license plate light connector. Nothing fancy, just pulled the male-female connector apart, laid the relay energizer wire across the male connector and pushed it back into the female. Friction of the connector holds the wire in place as tight as a solder joint. Not permanent, I know, but made for a quick connection. Have fun with the heated grips.
Chris Glennon - Portland, OR
cglennon is offline
