battery woes? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 04-05-2009, 05:42 PM Thread Starter
Concert connoisseur
wib714's Avatar
battery woes?
just got the bike out of the shop, they put in a new rr, they said the stator checked out fine and was charging. it has a new agm mf battery from autozone I just bought in october last time I rode. drove the bike home 12miles all was fine parked it in the shed and went to start it today and she was slow cranking. threw it on the charger for about an hour and the red light on the charger came on which means check battery. do you think I might have gotten a faulty battery from autozone like mentioned in the other threads and can autozone load test cycle batteries. god I hope it is just a battery issue that is still under warranty.
so what do you all think?
thanks.
I should be out riding not wrenching, its beautiful out!
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #2 of 12 (permalink) Old 04-05-2009, 06:11 PM
did you ride it all the time over the winter??? if not it may have lost its charge and could also be a faulty battery.... i know autozone can test batterys so im assuming they can help you out... if its bad make them replace it..
bigrepp61 is offline
post #3 of 12 (permalink) Old 04-05-2009, 06:14 PM
The Professor
lance328's Avatar
thanks.
Start the bike and check the voltage at the battery, at 4000 rpm's you dhould have 14v-14.5v.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #4 of 12 (permalink) Old 04-05-2009, 06:41 PM Thread Starter
Concert connoisseur
wib714's Avatar
got it started. battery showing 11.70 @ idle, rev her up to 4000rpm and only get 11.77
could it be the battery or did the shop not fix it with the new rr?
42,000 miles
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
wib714 is offline
post #5 of 12 (permalink) Old 04-05-2009, 06:58 PM
The Professor
lance328's Avatar
The R/R is not working, take it back and make them fix. Don't let them BS you, They said they fixed the problem but didn't. Do not pay another penny. It is their problem!
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
post #6 of 12 (permalink) Old 04-05-2009, 07:22 PM
cglennon's Avatar
You should see 12+v at idle and about 14.5v @4000 RPMs. I would take it back to the shop.
Chris Glennon - Portland, OR
cglennon is offline
post #7 of 12 (permalink) Old 04-09-2009, 08:06 AM Thread Starter
Concert connoisseur
wib714's Avatar
battery checked good so its back to the shop with the bike. will let you know the results in a couple days.
42,000 miles
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
wib714 is offline
post #8 of 12 (permalink) Old 04-09-2009, 07:34 PM
Calif Rider
weh44att's Avatar
I really thing a lot of cycle shops out there really do not know what they are doing. Most are screw shops, there are some good ones but they may be hard to find a local one. Here were I live there are no good ones. My son took his bike a few years ago to a Honda dealer to change the oil for the first time on his new bike. They stripped out the oil drain plug, and then tried all sort of things to fix it and non of their fixes worked. It was lucky that the bike had two drain plugs, he just JB welded the stripped one. Oh yes the shop said he must have stripped the plug himself, because they said they didn't do it.
2004 25,500 miles
Led tail light enhancement
Homemade floor boards
Headlight modulator
Extra heat sink on R+R
R+R relocation
Homemade driver's backrest
Fused Stator
Mcct conversion-cost 4.50
Ride-on in tires
iridium plugs
coil pickups adjusted.
weh44att is offline
post #9 of 12 (permalink) Old 04-10-2009, 04:17 PM
cglennon's Avatar
My last time in the dealer checked the battery, but never hooked it backup. They just left the cable loose, but touching the terminal. A few miles from the shop the cable must have warmed up and began to stretch out. The bike started to sputter and then died. No power at all. I pulled the seat and there was the battery cable, not connected to the battery. Good thing the Vn750 has a little tool set or I would have been stuck. Needless to say I had such a potty mouth for the rest of the ride home.
cglennon is offline
post #10 of 12 (permalink) Old 04-11-2009, 12:36 PM
Fire Ant's Avatar
That wouldn't surprise me. When I bought my bike, I asked them how to take the seat off. They actually told me that the bolts were located behind the plastic side panels...
--FA
K.J. "Fire Ant" Lord
VROC #28807
Decatur, TX
'03 VN750 "Serenity"
Rear Turn Signal Relocation
Front Brake Replacement
Spline lube, per Fergy's excellent instructions (that he has posted around here somewhere)
Kevlar Clutch Plates
Metzeler ME880 Tires
Stebel Nautilus Air Horn
ACCTs Rebuilt
Saddlemen Explorer Seat
MCCTs Installed
Kuryakyn Wide Levers Installed
Fire Ant is offline
