Spark Plugs Recommended? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 05-21-2019, 04:19 PM Thread Starter
Jason Pittenger's Avatar
I'm considering a new set of plugs. I'm over 21,000 miles and no idea if these are the original plugs or not. I've heard the NGK Iridium IX plugs (DPR7EIX9) are an improvement over the stock plugs (DPR7EA9). Is there a noticeable improvement, or is it just the advantage of having lifetime plugs in the bike?
Has anyone tried Denso Iridium Power (IX22B) plugs? This was the cross-reference on the Denso website. They have a U-shaped ground electrode, claiming better flame kernel growth. https://www.denso.com/global/en/prod...wer/index.html
I'm also curious about Denso's TT plugs.
https://www.denso.com/global/en/prod...lug/iridiumtt/
They have Iridium tips on both the center and the ground electrode. The realistic advantage I could see here, is our two plugs fire in opposite electrical polarities. By that, I mean one plug has a very high positive voltage on the center electrode, and the other plug has a very high negative voltage on the center electrode. The spark travels in opposite directions in the two plugs. The TT claims to be designed for bi-directional spark travel, vs standard shaped plugs.
Regarding twin tip plugs in general, I found this on Advanced Auto's website https://shop.advanceautoparts.com/r/...en-spark-plugs
"Double platinum spark plugs were designed for 'waste spark' DIS. In a waste spark system, the spark jumps from the center electrode to the side electrode for the cylinder that’s on the compression stroke. To return the electrical pulse back to the ignition coil pack, the spark jumps backwards (side-to-center) on the partner cylinder. Since the partner cylinder is on its exhaust stroke, nothing ignites and the spark is 'wasted.' You can’t use single platinum spark plugs or traditional copper spark plugs in these systems because the side electrodes aren’t designed to handle the reverse spark. But double platinum spark plugs, with a platinum disc welded to their side electrode, work exceptionally well. Both the center and side platinum discs remain sharp, allowing sparks to fly easily in both directions without causing rapid electrode wear."
That seems like it would be an advantage here, but I don't know if it's just hype.
I don't have a part number for the Iridium TT plugs. The cross-reference only pointed me to the Iridium Power plugs.
Completed modifications:
Planned modifications:
Last edited by Jason Pittenger; 05-21-2019 at 04:23 PM. Reason: Added last two sentences
Jason Pittenger is offline
post #2 of 6 (permalink) Old 05-21-2019, 09:12 PM Thread Starter
I thought about this more on my way home. Both iridium and iridium TT spark plugs claim a faster flame growth. Basically and effectively, it seems like it advances the ignition slightly. Assuming it doesn't cause knock, that would provide more power and more fuel economy. Couldn't I get the same results with a manual ignition advance? I wonder if that is all of where the advantage comes from, is the faster start of the flame front.
They also claim that the plugs changed the shape of the flame, which could not be duplicated with an ignition Advance. The flame appears to travel downward better, based on their literature.
There is definitely also the lifetime advantage of iridium. And, the TT does have the bi-directional capability that no other plug does quite as well.
post #3 of 6 (permalink) Old 05-21-2019, 11:28 PM
Retired USAF (IYAAYAS)
Chris and Shim's Avatar
I never felt any difference with my plugs but that doesn't mean there's not an improvement. About the only thing I can report is my bike seems to crank pretty easily.
Saddlebags, hard mounted
Fork mounted tool bag (now hard mounted)
Relocated rear turn signals
LED turn signals, brake lights and running lights
LED license plate frame
Engine Guard and Highway pegs
National Cycles Low Boy Heavy Duty windshield
Home made lowers (nice)
Custom seat (made by a local guy)
Iridium plugs (DPR7EIX-9)
Shenko 230 Tour Master tires at 11,123 miles
Splines lubed at 11,123 miles
Luggage rack
Light bar with LED lights
Progressive 412 shocks
Chris and Shim is offline
post #4 of 6 (permalink) Old 05-22-2019, 04:19 PM
flitecontrol's Avatar
Advantages are the electrode doesn't wear much, if at all, meaning the plugs don't need to be periodically re-gapped or replaced, they are cheaper, over their lifetime, than regular plugs and they provide a consistently good spark. It's doubtful that they provide any significant performance enhancement over fresh, standard plugs, in spite of advertising hype to the contrary.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #5 of 6 (permalink) Old 05-22-2019, 09:22 PM
I'm a rider
One1's Avatar
Old simple bikes like old simple plugs. /end
I have a CJ7 that pretty much refuses to run on anything but cheap ac delco plugs. That’s what the 258 was designed for, that’s what it likes.
1981 KZ750
1988 Vulcan VN750 (red)
2005 Vulcan VN750 (silver)
(2) 1994 Vulcan VN750 (red)
One1 is offline
post #6 of 6 (permalink) Old 05-23-2019, 05:32 PM
As far as starting, the Vulcan 750 has always been hard to start. I tried the expensive iridium plugs, and noticed no difference. I have noticed that the Vulcan engine turns over slower than on every other bike I've ever had. I did take the starter apart on one and it was filthy inside. I also replaced the brushes. But the cranking speed did not increase. I have connected it to a huge truck battery (12V) with way more amps than the Vulcan starter requires, it still turned over somewhat slowly. I noticed my Sportster does that too, but it has a really long stroke engine. The Vulcan has a short stroke engine, and it seems like it should turn over a lot faster than it does. Might be a design problem with the starter. Many inline fours turn over faster with the starter than they do when running at idle.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
