blah. another charging thread. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 04-02-2009, 09:40 PM Thread Starter
rider
global_recon's Avatar
hey everyone.
it's been a while. finally getting a chance to get justice back on the road. here's a weird charging thing... i haven't taken all the readings yet, but i have a voltmeter permanently wired up near the headlight. getting these readings:
idle (1500 rpm): 13.8v
as i rev the engine, volts go _down_.
4000-5000 rpm: 13.1v.
any ideas off the top of your head? just need to deal with this and then take care of a clutch issue and i'm back on the road.
thanks!
paul
1991 vn750: 'for great justice'
http://www.globalrecon.org
follow my rides on twitter: http://www.twitter.com/globalrecon
global_recon is offline
post #2 of 8 (permalink) Old 04-02-2009, 11:51 PM
Have you checked all the connectors and grounds to make sure everything is clean and tight. Sorry but I don`t know anything specificly that would cause this.
post #3 of 8 (permalink) Old 04-03-2009, 01:08 AM
Mine changes like that some times. As long as I am getting a good charge I don't worry about the veriance in volts.
post #4 of 8 (permalink) Old 04-03-2009, 12:40 PM
cglennon's Avatar
Does the headlight brightness increase with the RPM increase? If so, then the change in resistance across the circuit (i.e., bright bulb=low filament resistance) will cause this. Especially if the volt meter is electro-mechanical (i.e., it need current to move the needle). This happened to mine (electro-mechanical type) when I hooked it up initially in the same circuit as the gauge bulb. I moved the gauge bulb power lead to the license plate circuit and problem solved. However, the gauge is wired to my heated grip circuit (to take advantage of the relay), so I still get a voltage drop (actually if fluctuates due to the heat troller) when the grips heaters are on. I just turn off the heaters if I need an accurate reading.
As a test you might try running the gauge power lead to the battery directly. If that works, then add a relay or move the power lead to another circuit (i.e., one that is not on all the time).
Chris Glennon - Portland, OR
cglennon is offline
post #5 of 8 (permalink) Old 04-03-2009, 09:14 PM Thread Starter
rider
thank you for the responses.
the voltmeter i have rigged up is a digital meter and the headlight brightness doesn't fluctuate with the engine speed. i was digging around for another multimeter to measure the voltage at the battery and came across an old r/r that i thought was bad at one point. hooked it up and now the volts both at the meter wired near the headlight and at the multimeter right on the battery start at 12.5v or so during idle and then go up to 14v at about 5000rpm. soo....
apparently it was the r/r. apparently a screwed up r/r can cause the inverse volt behavior. there you have it. i hesitate to say 'problem solved'... so i won't. problem stalled.
thank you again.
paul
post #6 of 8 (permalink) Old 04-04-2009, 12:20 AM
Love My Baby
rubyrick's Avatar
I've noticed that my voltage increases from idle to about 3000 rpm, then it starts to decline just a touch from 3000 to 5000 rpm. Is this a potential problem?
Rubyrick
MY BABY...
'05 VN750
16,000 miles +
Kawi tank bib
Kawi rear rack
Small windshield
DEKA M/F battery
LED license plate frame
X
rubyrick is offline
post #7 of 8 (permalink) Old 04-04-2009, 01:46 AM
The Professor
lance328's Avatar
Depends on what your voltage is, normaly once your voltage hits 14.5v the R/R will bleed off excess voltage.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #8 of 8 (permalink) Old 04-04-2009, 04:24 AM
750Doug's Avatar
thank you again.
That's what you should see happening, and if it continues to climb approaching/reaching 16v then the battery will cook, and indicates a problem again. Sounds like its working fine now.
And that would be the best way to check a bikes voltmeter; get a hand held unit and check the voltage at the battery, at idle, and then throttled up to 2500, 3500-4000, etc.
And a low or slightly low reading could be something as simple as a bad/loose/dirty connection somewhere.
750Doug is offline
