left rear turn signal - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 04-05-2019, 01:49 AM Thread Starter
so i got my front two working and the back right but when i hook up the back left to the black/yellow ground and red positive it stays on like a running light
Jesse Lynch is offline
post #2 of 5 (permalink) Old 04-05-2019, 02:22 AM
The wires to the turn signal should be black/yellow ground and dark green positive. Has there been any custom work done on the rear end? Possibly you're tied in to the license plate light wire?
Vulcan slang for newcomers
Service Manual Download
Thorn is offline
post #3 of 5 (permalink) Old 04-05-2019, 01:34 PM Thread Starter
they cut all the wires leading to the back cause they wanted a bobber. i don’t have a green one i have a bk/y and r and then for the right side i got bk/y and grey for positive i looked at a diagram and it said green to for the left but i don’t see a green wore
post #4 of 5 (permalink) Old 04-05-2019, 01:54 PM
You'll have to trace the wires back to where they chopped the wiring harness and find the correct wire. It's possible they spliced the wrong wire, or there's a short between the tail light wire and the signal wire.
Is there a tail light on this thing anywhere? You can check for continuity (there shouldn't be continuity) between the right blinker lamp and the running light when the blinker module is removed.
Thorn is offline
post #5 of 5 (permalink) Old 04-05-2019, 06:06 PM Thread Starter
yeah the tail/ brake light work fine and i traced it back and found two black wires that they put on so i got all the blinkers working now just gotta wire them up and now i’m having trouble with the carb it’ll start and run but when i give it gas it dies and it’ just started doing this a couple days ago
