Turn Signals - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 3Likes
  • 1 Post By Chris and Shim
  • 1 Post By Jason Pittenger
post #1 of 5 (permalink) Old 04-02-2019, 09:11 AM Thread Starter
Turn Signals
Hey guys,
I pulled my bike out of the garage last night and got it running after the winter. I took it for a shakedown ride and noticed that the turn signal indicator on the cluster flashes really fast. The front left turn signal doesn't work and the rear left flashes quickly.
I would assume that the bulbs are bad in the front, but is that causing the issue for the whole system?
With that in mind, would you guys recommend replacing with OE turn signals/bulbs if necessary or have you guys used aftermarket LED or non-LED options that you would recommend? (I've been thinking about doing an LED swap for some time but don't have a whole lot of electrical background). Where would I find replacements?
Brandon Ollhoff
1995 VN750
Milwaukee, WI
Planned modifications:
USB Outlet + Voltmeter
LED headlamp
LED turn signals
Ear Shave (possible)
BOllhoff is offline
post #2 of 5 (permalink) Old 04-02-2019, 09:48 AM
Retired USAF (IYAAYAS)
Chris and Shim's Avatar
Go online and take a gander at CustomDynamics.com These folks have a slew of LED sets and options for you. On mine, with the exception of the added-on front white LED running lights, the rest came from CustomDynamics (I think its spelled as one word.) You'll be very happy with how much brighter (and therefore more visible) your machine will be.
I haven't yet done my headlight.
BOllhoff likes this.
Saddlebags, hard mounted
Fork mounted tool bag (now hard mounted)
Relocated rear turn signals
LED turn signals, brake lights and running lights
LED license plate frame
Engine Guard and Highway pegs
National Cycles Low Boy Heavy Duty windshield
Home made lowers (nice)
Custom seat (made by a local guy)
Iridium plugs (DPR7EIX-9)
Shenko 230 Tour Master tires at 11,123 miles
Splines lubed at 11,123 miles
Luggage rack
Light bar with LED lights
Progressive 412 shocks
Chris and Shim is offline
post #3 of 5 (permalink) Old 04-02-2019, 06:52 PM Thread Starter
Question for you, did you have to do any major mods to make their turn signals fit? Or was it essentially plug-n-play?
Brandon Ollhoff
1995 VN750
Milwaukee, WI
LED headlamp
LED turn signals
BOllhoff is offline
post #4 of 5 (permalink) Old 04-02-2019, 07:18 PM
The actual LED lights are embedded in some sort of brownish material, I wish that I knew what that stuff was called. I can't speak for any other type bike's installation but on the 750 I needed to trim down the circumference with a roto-tool before it would fit inside my turn signal housings.
A bit dusty to do but easy and once done, its done. Zero other issues.
For my rear turn signals, I had to drill a small hole in the bottom of the housing because the factory wiring only feeds power to the turn signal portion of the setup. My particular LED package also allowed the turn signal housings to additionally function as always-on running lights and on top of that brake lights, too. So they needed separate wires for their power.
Sure, you can get just LEDs that literally plug in to the factory socket exactly like factory bulbs but you wouldn't have the added functions as my kit has. So if you want to add those functions there will be a little bit of soldering and such.
Still, it was fun to do and can be done in one day for sure.
Luggage rack
post #5 of 5 (permalink) Old 04-03-2019, 06:30 AM
Jason Pittenger's Avatar
Yes. The flasher relay is designed to flash faster when a bulb is burned out. Replace the front bulb and the flash rate will return to normal.
If you change to LEDs, this feature will bite you again, unless you replace your flasher with an LED compatible one. I think its a EP34? But I am not 100% confident in that number.
Completed modifications:
Jason Pittenger is online now
Tags
headlight , led , turn signals
