Page 1 of 2 | 1 | 2 |
95 vulcan 750
okay guy i bought a vulcan 750 and the flasher relay was bad so i put a new one in and now all the light including the headlight and taillights flash except the blinkers but when i take it out they just stay on as running lights
Sponsored Links | |||
Sounds fancy. Care to post the part # you ordered, and a picture of how it's wired in to the bike? Did you have to splice wires to get it installed?
Vulcan slang for newcomers
Service Manual Download
don’t got a parts but i can take a pick of where it hooks in and of the relay if that helps
it’s like when someone hit the panic button on a car but idk why it does it with the old relay in all it does it click and the flashers don’t flash they stay solid
Any pictures would be helpful.
Just to clarify, because I think this is what you're saying is happening but it doesn't make any sense with stock wiring, when neither the old nor the new module is installed, the turn signals (front and back) come on as running lights?
With the new module installed,
Does the flashing start as soon as you turn the ignition to on, or only when you flip the turn signal switch to either side?
What happens when you turn on your hazards?
sorry been busy to post pics it’s starts flashing as soon as the ignition is on but i got another problem with it im spilling oil out of the crankcase breather hose but i’m not losing any power but i’m wondering if i can test the compression in the front head and see if that will tell me if i got a cracked head
it was the wrong relay got the right
Glad you got it figured out.
but i’m curious if the front are blown will the back not blink
If a blinker is blown, the other blinker on the same side should blink at twice the normal rate. One bad light will not cause other lights to not blink at all.
Sponsored Links | |
Bookmarks |
Previous Thread
Next Thread
Thread Tools | |
Display Modes | |
Posting Rules | |
