Ignition switch - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 12-22-2018, 03:26 AM Thread Starter
Ignition switch
I need a diagram of the contact points for the wiring on the inside of the ignition switch for my 95 vulcan 750 please!!!!
DallasT is offline
post #2 of 3 (permalink) Old 12-22-2018, 03:30 AM Thread Starter
Trying to figure out which contact to solder the brown/ white wire to. They are labeled l1,l2,l3,b1,b2, ect.....
DallasT is offline
post #3 of 3 (permalink) Old 12-22-2018, 02:26 PM
Link to your original post on this: https://www.vn750.com/forum/19-elect...g-problem.html
Unless someone has a picture of the switch, with the pigtail attached and exposed to guide you, replacing with an OEM switch and pigtail is going to be the most simple way to fix this. Otherwise, you're going to need to spend time with the top left of the diagram, an ohm meter, and the OEM switch to find your own pinouts.
I haven't found a direct pin diagram for the OEM switch. At the top left of the wiring diagram, it shows the general connections, but not exactly where they go on the switch.
The br/w is shown on the "park" circuit. That wire changes to all brown and is the monitor wire for the r/r. It needs battery voltage when the key is on/run.
