Ignition switch wiring problem! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 12-11-2018, 07:43 AM Thread Starter
My 95 caught on fire a while back and I've been restoring it and am stuck on wiring in an aftermarket switch. There are four wires, a red, green, black, and blck/why on the switch, and red, blue, or/green, white, yellow, br/ white, and wht/ black from the harness. Any ideas on what colors to conect? And what is the br/why wires job?
DallasT is offline
post #2 of 6 (permalink) Old 12-11-2018, 11:56 AM
See if this pic works, will need to zoom in to read the text, it's a color diagram: https://www.vn750.com/photopost/data...ingcolored.jpg
Br/W runs to the junction box, but also has an all brown that branches off the br/w, it's the charge voltage monitor for the R/R.
post #3 of 6 (permalink) Old 12-16-2018, 01:45 PM Thread Starter
I have downloaded that diagram, and still cannot get it wired correctly. Does the diagram have the white, yellow, and brown/ white wires together and the blue and red together, and the orange/ green with the white/ blk.? If so what colors do those combos connect to? It seems I have tried every known combo. I have also checked the coils and have 12 v in the coil wires still no spark. I have grounded the bl.wire of the jb. As well as bl.and white wire of the ignitor box. When I turn the key on, the headlight comes on, low beam and high beam work, tail light comes on but start button doesn't work and no spark when I jump at the selanoid but bike turns over. How do I check the ignitor box with multi meter as the manual says remove box and test??? I dont get it, I e spent hours and hours researching and testing, what am I doing wrong? I also tried the coil mode bypassing the harness and still nothing.
DallasT is offline
post #4 of 6 (permalink) Old 12-16-2018, 01:46 PM Thread Starter
Do I just need to save up for an OEM ignition switch????
DallasT is offline
post #5 of 6 (permalink) Old 12-16-2018, 03:00 PM
Check ebay for a switch, they're plug n play.
I don't have time to dig into the diagram and manual right now, but will try to later this evening.
All those wires mentioned that you grounded, are not grounds. Grounds on this bike are black with yellow stripe. Here's hoping nothing is cooked. Those wires need put back where they belong.
post #6 of 6 (permalink) Old 12-17-2018, 10:35 AM
The blue wire at the JB can either be the switching ground for the cooling fan, or the wire for the headlight relay, depends which plug it came from. 8-pin or 10-pin?
If I'm seeing the blurry letters correctly, the black/white at the IC runs directly to the JB, so reconnect that.
For the ignition switch, the diagram shows: orange/green, red, white/black, yellow, blue, white, brown/white. Sorting out which terminals is another problem that I'll have to look at later.
Here's a search for switches at ebay: https://www.ebay.com/sch/i.html?_fro...pg=100&_sop=15
