Dielectric grease... - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 03-30-2009, 02:18 PM Thread Starter
FalseFiction1's Avatar
I'm going to be relocating my R/R tonight. It is already off, I just need to paint the bracket that I made and hook everything up. The question that I have is how much dielectric grease do I use when I plug the R/R back in?
FalseFiction1 is offline
post #2 of 7 (permalink) Old 03-30-2009, 02:30 PM
Jace Bror's Avatar
A whole tube.
No if you put some in the female side of the plug it will do. Most of the diaelectric grease will squish out when you make the connection. It is mainly to help seal up the area from water getting in.
Sold 750 (9-09)
Mustand Seat (6-09)
Balanced Carbs (4-09)
Adjusted Mix Screws (4-09)
R/R Relocated (3-09)
Splines Lubed (3-09)
Painted flat blak (3-09)
Kuri grips (8-08)
Kuri Longhorn pegs (8-08)
Iridium Plugs (8-08)
Highway bar/ engine guard(FS)
Facebook ID Eli Gaffke
Jace Bror is offline
post #3 of 7 (permalink) Old 03-30-2009, 02:31 PM
Chucklehead
dragon159's Avatar
Just a dab, enough to coat the terminal surface lightly.
"Squirrel Bike" aka Jersey
Rat bike with a good PR agent
shaved and coastered
2 into 1 exhaust
rear 170 and front 110
custom dash with voltmeter
Spitfire windscreen
Plutonium plugs
More to come
dragon159 is offline
post #4 of 7 (permalink) Old 03-30-2009, 02:35 PM Thread Starter
Easy enough. Thanks for your feedback.
post #5 of 7 (permalink) Old 03-30-2009, 02:41 PM
Vintage bike addict
antiq's Avatar
There sould be enough packed into every female connector to squeeze out when the connectors are put together.
Eleanor Roosevelt.
antiq is offline
post #6 of 7 (permalink) Old 03-30-2009, 03:11 PM
The Clymer manual has almost a whole column regarding connectors and dielectric grease.
To use, thoroughly clean and dry both male and female terminals.
Pack the interior of one of the connectors prior to connecting the 2 halves.
On MULTI-PIN CONNECTORS pack the MALE SIDE.
On SINGLE PIN CONNECTORS pack the FEMALE side. Use a good sized gob so it squishes out when joined. It should fill the entire inner area.
On multi-pin connectors also fill the backside of both male and female connectors to prevent moisture entering there. Wipe off excess.
Dielectric grease is an insulator, sealer and waterproofer, but will not interfer with current flow if the terminals are clean and tight.
post #7 of 7 (permalink) Old 03-30-2009, 03:39 PM Thread Starter
Just finished it. Thanks guys.
