final update to electrical charging problem - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 1 (permalink) Old 11-05-2018, 03:45 PM Thread Starter
I have cleaned all the wiring connectors, re soldered the stator leads, removed the signal wire from the r/r per ricks electric, checked and cleaned all the grounds replaced the jb and r/r. Had the battery stress tested and have this morning run thesre latest tests:
cold engine:
key off:
stator lead resistance test:
a1 to a2 .6 ohms
a1 to a3 .6 ohms
a2 to a3 .6 ohms
continuity test stator leads to ground
a1 0 with tone
a2 0 with tone
a3 0 with tone
resistance test stator leads to ground
a1 .4 ohms
a2 .5 ohms
a3 .4 ohms
Cold running
a1 to a2 58 vac
a1 to a3 58 vac
a2 to a3 58 vac
Hot:
resistance test between stator leads
a1 to a2 .7 ohms
a1 to a3 .7 ohms
a2 to a3 .7 ohms
a1 0 with tone
a2 0 with tone
a3 0 with tone
a1 .5 ohms
a2 .5 ohms
a3 .5 ohms
Hot running voltage ac test
a1 to a2 52 vac
a1 to a3 52 vac
a2 to a3 54 vac
Thanks for all your help guys. I couldn't have made this much progress without your assistance.
Dave
dbeech is offline
