final update to electrical charging problem - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 14 (permalink) Old 11-05-2018, 01:33 PM Thread Starter
Hi All,
I have finished cleaning all the connectors on the bike. I went back and re soldered the stator connections. I have removed as many bullet connectors as possible and soldered the wiring back together. This morning I did a few tests and need them checked and verified by you. Your information has been invaluable. So here it is...
Cold test
resistance between legs
a1 to a2 .6 ohms
a1 to a3 .6 ohms
a2 to a3 .6 ohms
ground test
a1 to ground .4 ohms with different meter 0 with tone
a2 to ground .5 ohms with different meter 0 with tone
a3 to ground .4 ohms with different meter 0 with tone
Running ac test
a1 to a2 58 vac
a1 to a3 58 vac
a2 to a3 58 vac
Hot test
a1 to a2 .7 ohms
a1 to a3 .7 ohms
a2 to a3 .7 ohms
ground test
a1 to ground 0 with tone
a2 to ground 0 with tone
a3 to ground 0 with tone
vac test
a1 to a2 52 vac
a1 to a3 52 vac
a2 to a3 54 vac
Thanks for all the help guys. I couldn't have made any progress without your input.
Dave
dbeech is offline
post #2 of 14 (permalink) Old 11-05-2018, 02:47 PM
Shouldn't the legs of the stator be infinite resistance to ground?
Vulcan slang for newcomers
Service Manual Download
Thorn is offline
post #3 of 14 (permalink) Old 11-05-2018, 04:43 PM
Originally Posted by dbeech View Post
ground test
ground test
Dave
The first test says it's toast (cold).
The second test says it's toast (hot)
A tone on my meter indicates continuity, a connection.
__________________________________________________ ______
Any meter reading less than infinity, will indicate a connection to ground. Example .3849002 indicates a connection bearing that many ohms (shorted to ground). If your meter doesn't use the infinity symbol, you may see OL (open line), which will mean there's no connection to ground (good).
Below is from the manual, except I changed the word alternator to stator. Don't know why they have two tests listed, "installation" and "insulation". They're both the same test except the range settings. There should be no connection between ground and the stator coils (leads).
Stator Coil Installation Test
1. Disconnect stator leads.
2. Using the highest range of the tester, measure the resistance between each yellow lead and chassis ground.
*Any meter reading less than inifinty () indicates a short, necessitating stator replacement.
Stator Coil Insulation Test
Meter range: 1 x kΩ
Connection: Stator leads (disconnected)
.. One meter lead - One yellow stator lead
.. Other meter lead - Chassis ground
Reading: No reading (∞Ω)
∞Ω (infinite ohms)
__________________________________________________ ______________________
post #4 of 14 (permalink) Old 11-05-2018, 04:47 PM
From google: For the purposes of most electronic circuits, you can assume that the resistance value of ordinary wire is zero ohms (0 Ω)
Zero ohms is less than infinty. Which means you have a great connection to ground, and that's bad in this case.
post #5 of 14 (permalink) Old 11-05-2018, 06:10 PM
ubertalldude's Avatar
I wonder about this, too, but if he was shorting to ground, how is he still getting such good voltage leg-to-leg?
ubertalldude is online now
post #6 of 14 (permalink) Old 11-05-2018, 06:29 PM
Question
I also wondered how it's getting such good DC volts at the R/R. Makes no sense.
post #7 of 14 (permalink) Old 11-05-2018, 11:06 PM Thread Starter
This is the last post on the beginning thread. Hope it makes some sense. I feel like I'm beating a dead horse.
Hi All, Here is the latest update. I have had my gel battery stress tested and it passed. Next I removed the bullet connectors from the stator and soldered the joints. I went to the other side of the bike and removed the white/red wire bullet connector and soldered that joint. Did a test this morning and at 3000 rpm cold to warm got 13.14 to 13.2 vdc across the battery. When the bike kicked the fan on, the voltage dropped to 12.6 to 12.8 vdc. I revved the engine and the vdc out of the r/r increased but I could only get high 13's. even after the time at the lower voltage, the battery measured 13.18 vdc across the battery when shut off. Thanks again for all your help
dbeech is offline
post #8 of 14 (permalink) Old 11-06-2018, 05:02 AM
for future reference, this is the thread outlining the initial problem: https://www.vn750.com/forum/19-electrical/103235-charging-system-problems-newbie.html
I would suspect that you've got an intermittent short in the stator. The measurements you're posting don't really make sense, like others have mentioned. Good AC voltages, but with paths to ground on the stator legs. It's possible that the AC measurements taken with a multimiter are able to ignore a fair amount of grounded current when determining the AC voltage (reading more of a choppy square wave than a sine wave, but is only checking general peak values, ignoring an inconsistent hertz clock). You're probably not getting the full DC voltage that you should, and if there is an intermittent ground, you're probably generating heat at that contact point, weakening the insulation further, and it's going to blow out the winding eventually. But that's all just a guess.
Do you know someone with an oscilloscope? That would be waaaay more informative about what is actually going on when the bike is running.
Still, you seem to be able to charge your battery with moderate rpms, so ... ride it until it craps out and then replace the stator when you really know it's bad?
If you disconnected the battery from the bike with a solid stator, the bike would continue to run.
If you disconnect it on yours, I suspect the engine would at some point sputter and die. It's might be worth doing just to see.
Thorn is offline
post #9 of 14 (permalink) Old 11-11-2018, 03:12 PM Thread Starter
Thanks for all the help guys. I am just going to proceed with the tuxedo mod if my mechanic will do it. I will be needing to purchase the mod kit if it's still available. I would have responded sooner but been sick and away from the computer.
dbeech is offline
post #10 of 14 (permalink) Old 11-11-2018, 08:50 PM
kryptonianjorel's Avatar
Do you have the space to do the tux mod? If you do, it is really easy and a great way to learn more about the bike!
kryptonianjorel is offline
