a really quick battery question - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 11-04-2018, 11:56 AM Thread Starter
Hi All,
I have a bikemaster trugel battery in my 1994 vn750. I also have a battery tender jr. The folks at the manufacturer say it should charge the battery to 14.5 vdc. I have been charging this battery during the time I have been working on the electrical charging system and todate, It has only charged the battery up to 14.5 vdc twice. Do you all think the battery tender is bad or is this just normal? It charges to 13.2 to 13.4 vdc normally.
Thanks for your help.
Dave
dbeech is offline
post #2 of 4 (permalink) Old 11-04-2018, 12:02 PM
Headbanger/Popes of Hell
ruger's Avatar
well, the manufacturer did say "it SHOULD", not it would.
there is always the chance the battery is going bad too.
ruger is online now
post #3 of 4 (permalink) Old 11-05-2018, 07:45 AM
ubertalldude's Avatar
the tender charges up to a certain point but will let the voltage float down at the end of the charging cycle. if the lights come on the tender is good most likely, it has self testing circuitry built in.
if the battery rests around 12.7-13.0 v when taken off the tender for a few hours, then the battery and charger are good. 12v batteries should rest around 12.6-13.0 v when fully charged and in good health.
ubertalldude is offline
post #4 of 4 (permalink) Old 11-05-2018, 01:14 PM Thread Starter
Thank you,
I spoke with deltran this morning and based on what you said and what they said about the gelcel application everything is working just like it is supposed to. Thanks again.
dbeech is offline
