start on one cylinder. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 2Likes
post #1 of 13 (permalink) Old 10-14-2018, 09:13 AM Thread Starter
Send a message via Skype™ to Ssergg
Hey. I live in Minsk, Belarus, and I immediately forgive me for my poor English.
I dropped my bike with the engine running.
After that, I could not start it anymore.
In search of a problem, I accidentally overheated that it was easy to start on one cylinder.
My friend had a similar problem and the solution was to completely replace the electrical wiring.
Maybe there is a simpler solution to this problem?
Ssergg is offline
post #2 of 13 (permalink) Old 10-14-2018, 10:47 AM
ubertalldude's Avatar
your English is understandable.
does the engine spin when you press the start button? dropping the bike with the engine running should not cause electrical damage unless you were traveling quickly. check the switch on the sidestand / kick stand, that would be my first thought. there are several other switches on the motorcycle that could cause the engine not to spin when you press start, and there are ways to bypass them. we can help figure them out with you as long as you have electrical and mechanical knowledge
ubertalldude is offline
post #3 of 13 (permalink) Old 10-14-2018, 11:05 AM Thread Starter
Perhaps the fall of the motorcycle and the problem appeared just a coincidence in time.
I think if the engine runs on one cylinder is not a mechanical problem.
I press the start button and the starter turns the engine, but the engine does not start.
I unscrew the candle from the front cylinder and put it on the wire.
I press the start button and the engine starts and runs.
I see a spark on the twisted candle.
Based on this, we can assume that the ignition coil and spark plug are intact.
I put the candle in the cylinder, press the start button, the starter turns the engine, but it does not start.
I did this with both candles in the front cylinder several times with the same result.
I checked the petrol enters both cylinders
All four candles give off a spark.
I performed Blue Wire & Two Wire mods this spring.
And I drove more than 2000 kilometers during the season and had no problems with a motorcycle.
Ssergg is offline
post #4 of 13 (permalink) Old 10-14-2018, 06:26 PM
Could it be one cylinder filling up with gas? I'm just going by the way it sounded when you started it.
The engine rolled over, stopped, then you had to hit the starter again and it repeated. I didn't see any gas blow out of the open plug hole ... Does it blow anything out of the pipes when it starts? Does the oil smell like gas, or is overfull?
post #5 of 13 (permalink) Old 10-15-2018, 12:58 AM Thread Starter
I smell gasoline from an open cylinder. When I twist the candles they are wet
Ssergg is offline
post #6 of 13 (permalink) Old 10-15-2018, 10:04 AM
readparse's Avatar
Today I learned that spark plugs are called "ignition candles" in some places. I like it.
1986 Vulcan 750
Purchased June 2018, as a first bike.
Put 1,300 miles on it so far.
AGM Battery, Iridium Plugs
SeaFoam does wonders, and I'm protected by Ride-On
Back tire: Dunlop Challenger.
Front tire: Dunlop Challenger, but about to replace it with a Kenda Cruiser.
readparse is offline
post #7 of 13 (permalink) Old 10-15-2018, 10:28 AM
I'm thinking it might have a stuck float in one of the carbs. Would be the front cylinder since the other one runs.
Can you get it to start on the front cylinder only, as you did with the rear?
post #8 of 13 (permalink) Old 10-15-2018, 01:34 PM Thread Starter
I could not repeat yesterday’s experience. Motorcycle did't start.
I unscrewed the spark plugs from both cylinders. The power of the spark is different on them three times. Tomorrow I'll go to the store for a new set.
set 4 DENSO Iridium Power IX22B were installed at the very beginning of spring.
I'm not sure this will help, but I need to move on.
Ssergg is offline
post #9 of 13 (permalink) Old 10-15-2018, 02:03 PM
You should probably put the battery on a charger, I don't see the need to replace the candles. The battery is probably weak from cranking it and giving you weak spark. Maybe try tapping the carburetors with the plastic end of a screwdriver to free up what appears to be a stuck float. crank the engine with all candles removed to get the gas out of the cylinders, then try to start the engine with a freshly charged battery, you may get lucky
post #10 of 13 (permalink) Old 10-15-2018, 02:18 PM
I agree, the candles are probably ok.
Agree also, charge battery, and tap on the front carb bowl to free up the float inside.
