very hard starting - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 10-08-2018, 08:21 AM Thread Starter
Unhappy very hard starting
my 1997 Vulcan 750 wont start until I remove one spark-plug wire then it starts
glenn_nemeth is offline
post #2 of 8 (permalink) Old 10-08-2018, 01:40 PM
Does it die if you reconnect it?
post #3 of 8 (permalink) Old 10-09-2018, 07:49 PM Thread Starter
no+++ it does not die
post #4 of 8 (permalink) Old 10-09-2018, 10:34 PM
Does it matter which wire you pull? Left, right, front, rear?
Do you get spark on the loose wire?
post #5 of 8 (permalink) Old 10-10-2018, 09:22 AM
Perhaps you need new plugs. Am wondering how you discovered this. Seems like an odd procedure to try.....won't start? Pull a plug wire off?
post #6 of 8 (permalink) Old 10-10-2018, 10:26 AM
Maybe discovered while checking for spark?
I'm thinking a weak coil, maybe CDI problem, but I'm waiting to see more details. If it's just on one coil, ohm test that one. If it's on any wire on either coil, may be CDI.
post #7 of 8 (permalink) Old 10-10-2018, 02:53 PM
I'm thinking weak battery.....
As the bike runs with the plug wire reattached (after it starts)
Am guessing one coil fires both plugs in one cylinder.?
post #8 of 8 (permalink) Old 10-10-2018, 04:56 PM
Yes, front coil - front cyl, etc. What made me think weak coil, will fire one but not both. Could also be a pickup, not enough saturation for some reason. ... or CDI.
