Weird power outages - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 03-28-2009, 09:25 PM Thread Starter
Jace Bror's Avatar
Weird power outages
So I went to start my bike today. When I turned the key to on it had power, all the gauges lit up, but soon as I hit the starter button all I heard was a click and nothing then all the lites went off. When I would shake the bike some then it would come back and then I could start it. Now the only thing I have done recently was the RR. When I hit the button the click was on the right side, I think. Is there maybe a relay that could be going bad?
Sold 750 (9-09)
Mustand Seat (6-09)
Balanced Carbs (4-09)
Adjusted Mix Screws (4-09)
R/R Relocated (3-09)
Splines Lubed (3-09)
Painted flat blak (3-09)
Kuri grips (8-08)
Kuri Longhorn pegs (8-08)
Iridium Plugs (8-08)
Highway bar/ engine guard(FS)
Facebook ID Eli Gaffke
Jace Bror is offline
post #2 of 10 (permalink) Old 03-28-2009, 09:30 PM
The Professor
lance328's Avatar
Check and clean ALL battery, solenoid, starter and ground connections. It sounds like your battery to frame connection is loose. Also check batery voltage and check starter mount bolts.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #3 of 10 (permalink) Old 03-28-2009, 09:31 PM
Simple Solutions
seebeeare's Avatar
i had a similar event happen and it ended up being a loose ground right where the lead from the batt goes to the frame.... the tab broke off the wire in fact it was so intermitent it went on for weeks befor i pulled the batt and the wire actually fell thats how i found it check your grounds fuses and connections
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
How To Test the Stator
seebeeare is offline
post #4 of 10 (permalink) Old 03-28-2009, 09:33 PM Thread Starter
Jace Bror's Avatar
I did just put the batt back in after winter. I haven't changed to the MF battery yet. I know naughty me. Where is the starter at exactly? I'll have to check that stuff out.
Sold 750 (9-09)
Mustand Seat (6-09)
Kuri grips (8-08)
post #5 of 10 (permalink) Old 03-28-2009, 09:36 PM
The Professor
lance328's Avatar
Starter is below the oil filter, the oil filter is below the radiator.
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
post #6 of 10 (permalink) Old 03-28-2009, 09:47 PM Thread Starter
Jace Bror's Avatar
Ok so I remember where that is now. I may have been hearing the solenoid clicking, but if the power connection wasn't strong it wouldn't work. but why would all the lites go out. and then come right back on? The first thing I did was check the fuses. There are only 4 right? in the box on the left side. there arent any others are there? thats why i was thinking relays
Sold 750 (9-09)
Mustand Seat (6-09)
Kuri grips (8-08)
post #7 of 10 (permalink) Old 03-28-2009, 09:49 PM
The Professor
lance328's Avatar
A loose connection will cause this problem, pull the seat and check your connections.
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
post #8 of 10 (permalink) Old 03-28-2009, 09:53 PM
The Professor
lance328's Avatar
Also if your battery has crapped out this will happen. The lights will come on with minimal amps, you hit the starter button then all dies.
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
post #9 of 10 (permalink) Old 03-28-2009, 10:09 PM Thread Starter
Jace Bror's Avatar
I just went out and tried it bout 10 times, everytime not a problem. My meter is in my work truck so I'll have to wait to check things out.
Sold 750 (9-09)
Mustand Seat (6-09)
Kuri grips (8-08)
post #10 of 10 (permalink) Old 03-28-2009, 10:17 PM
Simple Solutions
seebeeare's Avatar
a low batt well in my case befor i got the mf batt right befor it went out there was enough juice for the starterr but not enough to fire the ignition system and it was usually in the am when i had the problem... I'd pull the seat and take a 10 mm with u and make sure all the bolts are tight the two on the batt the one on the frame the two on the sylenoide under the right cover (I think) and the endine to frame (this one will be an 8mm at the engine) and the wire connecting to the starter if i had to guess you will find it under the seat
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
