Engine Tilt Pics - Stator/Balancer Job - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 09-09-2018, 11:23 AM Thread Starter
Arrow Engine Tilt Pics - Stator/Balancer Job
Trying to restore these pics, but couldn't find the original thread I posted them in.
So here they are without much commentary, any questions, just ask away.
Airbox, coolant tubes at the heads, final drive, and thermostat housing/hoses are all removed. Final drive was off for a tire and spline lube, but this did make mating the bevel gear and driveshaft easier.
Carbs, throttle cables, bevel gear, and exhaust manifolds are in place, not removed.
Last edited by Spockster; 09-12-2018 at 10:23 AM. Reason: bevel gear and final drive
post #2 of 6 (permalink) Old 09-10-2018, 09:33 AM
b.k.forster's Avatar
How did you get the coolant tubes out?
and....... Son of a B$#@%^....... I didn't push the motor forward... the below kept happening....
b.k.forster is offline
post #3 of 6 (permalink) Old 09-10-2018, 09:38 AM
Thank you so much Spockster.... I was getting pretty frustrated at the apparent lack of room to just "rock the engine to the right" which everyone made sound so easy....
post #4 of 6 (permalink) Old 09-10-2018, 10:11 AM Thread Starter
Gently wiggle the tube while lifting up. (after removing the holdown bolt) Some spray lube should help, these steel tubes corrode with the aluminum head.
It looks like your airbox is still in place? I don't recall if it gets removed in the factory procedures, but I knew I wanted it gone for the engine tilt. Maybe since you removed the exhaust manifolds, it has enough room, but the airbox is shoehorned in there and takes up valuable space.
post #5 of 6 (permalink) Old 09-12-2018, 01:15 AM
Diesel Tech
DenverDiesel's Avatar
At that point, why not just disconnect the throttle cables and drop the engine out? You're 99% of the way there.
1989 VN750
Highway blaster
2006 Honda Rebel Diesel
100mpg, low and slow
1982 Mercedes 300D
Modified engine, 4-speed manual
DenverDiesel is offline
post #6 of 6 (permalink) Old 09-12-2018, 08:39 AM Thread Starter
Have a bad back and didn't want to wrestle the engine in/out by myself. It went back in a lot quicker this way, for me. Dang cables are usually tedious too.
Some might say.. But you have a floor jack. Yes, but the engine doesn't balance well on the jack, and I'd still have to lift it on/off the jack.
I've done many by just straddling the frame and lifting them out. Wouldn't do that now unless it's just a 250cc 2-stroke, or smaller.
