Charging issue!! Plz help. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 2Likes
  • 1 Post By Vman99
  • 1 Post By Spockster
post #1 of 9 (permalink) Old 08-18-2018, 08:59 PM Thread Starter
Vman99's Avatar
Question Charging issue!! Plz help.
Okay. I just got the bike back. Running decent after coming from the shop. In fixed there screw ups. But my bike is still not charging..... I have replaced these things so far. R/R, stator (Its tux modded but I didn’t do it.),battery. I rode it all day and she ran till she Killed the battery. Not sure what else it could be. Magnets? Any tips would be greatly appreciated and I will respond on what I have already tried thanks.
The stator is grounding out could it be because of the damn tuxedo mod that the other person did? I just put it in ther 7 months ago, and its only been running maybe a few days?
Yeah its a vulcan 750 cc damn righ.
Vman99 is offline
post #2 of 9 (permalink) Old 08-18-2018, 09:02 PM
need to start with some charging system troubleshooting.. its foolish to throw money at parts and not fix the issue. Need to find out exactly what the issue is then correct it
https://www.vn750.com/forum/19-elect...eshooting.html
post #3 of 9 (permalink) Old 08-18-2018, 09:39 PM Thread Starter
Vman99's Avatar
I havent just been throwing money at it. The r/r is fine no bubbles in the epoxy. The stator is fine there is no ground between the polls last time I checked and the battery is good I just had it charged and tested. I have been troubleshooting.
readparse likes this.
Vman99 is offline
post #4 of 9 (permalink) Old 08-18-2018, 11:07 PM
Need to fully re-test the stator and r/r, then post your results, ohms and AC voltage.
kryptonianjorel likes this.
post #5 of 9 (permalink) Old 08-19-2018, 08:40 AM
also check the bullet connectors between the stator and R/R while your doing the diagnosis. they are notorious for corrosion/bad connections, ect.
also, double check all the grounds...
the R/R you put in, was it a stock type replacement? or did you upgrade to a MOSFET style?
post #6 of 9 (permalink) Old 08-19-2018, 02:47 PM Thread Starter
Vman99's Avatar
Stocker I knew was good
Vman99 is offline
post #7 of 9 (permalink) Old 08-21-2018, 05:42 PM Thread Starter
Vman99's Avatar
Please recheck above spockster
Vman99 is offline
post #8 of 9 (permalink) Old 08-21-2018, 06:09 PM
If you're sure the stator is grounding out, then yes, the stator has probably shifted on the mod plate and that's the problem..
You also said the stator is not grounding between the poles, but that doesn't sound like a valid test. The one test is between stator leads and ground, there should be no continuity. Another test is ohms between leads. Last is AC voltage on each lead.
We can't advise without test results, most stators and R/Rs were good when first installed.
post #9 of 9 (permalink) Old 08-22-2018, 05:31 AM
JETHRO's Avatar
you need a multimeter and do tests yourself, its a must with this bike.
Vn 750 A2 1986 rebuilt engine, crank shaft, half casing,shell bearings,con rods,rear cylinder head,oil pump,water pump ,(had ceased bearing rusted up),tie bar upgrade,clutch basket drilled,front cylinder cam chains,toc springs,stator,shaved, rectifier,agm battery,solenoid ,starter motor (used) re-spray ongoing.
JETHRO is offline
Tags
electrical problem , r/r , stator
