Loose ignition? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 08-03-2018, 09:24 PM Thread Starter
Loose ignition?
Hey guys, I'm a new rider, a new Vulcan owner, and obviously new to the forum. My 93 Vulcan is my first bike. It runs great...for the most part. The only trick is starting. When you turn the key on you can't just push the starter. You need to hold the starter button and then wiggle the key. Then it'll start. Also, once its running it'll occasionally die. it doesn't sputter, just dies. Hit the starter and it starts right up again. I'm assuming the ignition itself is just shot. Thoughts?!?!? Thanks for the help, guys.
JBrooks is offline
post #2 of 5 (permalink) Old 08-03-2018, 09:55 PM
kryptonianjorel's Avatar
Sounds like a loose connection in the starter switch. Could be a loose ground somewhere too.
kryptonianjorel is offline
post #3 of 5 (permalink) Old 08-03-2018, 11:26 PM Thread Starter
Yeah, I was wondering. I may pull the switch and start checking wires before I buy a whole new switch.
JBrooks is offline
post #4 of 5 (permalink) Old 08-04-2018, 08:40 AM
may need to remove the 'puck' and carefully disassemble/clean and put a little stretch on the springs.
the ign switch on these bikes can cause all sorts of weird and random seeming issues
post #5 of 5 (permalink) Old 08-04-2018, 09:42 AM Thread Starter
That's what I've heard. I'll look up your suggestion and try that as well.
JBrooks is offline
Tags
ignition , key , starting
